DennisN Tired Old Man
Posted: Sat Nov 13, 2010 7:17 pm Post subject: |
Guivre46 wrote: | exportman wrote: | I agree that you can judge your speed, but it was much easier in A Morris Minor or a Ford pop. |
Ford Pop; now that was a car. Two foot gear lever, 3 forward gears, no heater - any speed felt like 70mph. | Mine was the sit up and beg model. Nieces wallpapered the outside of it and when the prop shaft broke, it needed a hammer and chisel to get the paint off the nuts and bolts - paint thicker than the metal on modern cars! _________________ Dennis
Two of them are obesiting!! |
Fellwalker Lifetime Member
Posted: Sat Nov 13, 2010 7:36 pm Post subject: |
exportman wrote: |
There are a few older people out here who remember when the sign that now denotes the national speed limit meant the end of speed limits. |
Which is what I meant.
exportman wrote: |
A modern car is quite smooth no wind noise fast acceleration it is more difficult to keep to the speed you would like to drive at. |
I want one without wind noise please.
exportman wrote: |
Still I bet Fellwalker subscribes to the speed camera database. |
Early on I reported three new cameras and got a lifetime subscription, but I do not have the PGPSW database (or any other) on my satnav. I used to but got so fed up of the constant warnings when I was within the speed limit that I took it off.
exportman wrote: |
On the static cameras. I agree there are a serious number of driver who brake when they see a camera no matter what speed they are doing, even if they are well within the limit. I often pass 50 mph cameras on the A556 between the M6 and M56 at busy time you are lucky to be doing 40 yet drivers still comfort brake before the cameras. | Damned annoying isn't it.
DennisN wrote: | So Fellwalker and I need for loads of speed cameras to get all the rest of you off the road.  |
Now there's a thought. Can we also remove the tailgaters, those that cut in too quickly after overtaking, and those that stop a car's length short of a traffic light (they aren't even on the embedded sensor, so it cannot know they are there).
Guivre46 wrote: |
And don't forget the windscreen wipers operating off the vacuum so that they stopped when you accelerated. My Ford Pop used almost as much oil as petrol above 50mph. _________________ Samsung Galaxy Note 9, Nexus 5, Galaxy tab S3. Also use OSMAnd+, Sygic Mobile Maps, and OS maps app. Also "Great Britain Topo Maps" and "Old Maps". Don't use speed camera database as sticking to the limit is safer. |
exportman Frequent Visitor
Joined: Mar 26, 2006 Posts: 261 Location: United Kingdom
Posted: Sat Nov 13, 2010 7:50 pm Post subject: |
Fellwalker wrote: |
And don't forget the windscreen wipers operating off the vacuum so that they stopped when you accelerated. My Ford Pop used almost as much oil as petrol above 50mph. |
My Gran had one with vacuum assisted brakes operated through a leaver on the steering wheel ( she was a little disabled).
Drove the Pop when I was 14 ( not on the road of course) first car to drive on the road was my mums Ford Anglia. First car I owned was a 1960 Morris Minor. It was almost as old as me.
I ride a motor bike most days, comparatively cars today have little or no wind noise. Certainly at city speeds there is no discernible noise in my Mondeo even at seventy is not bad. There is tyre noise but it is not that intrusive. Turn on the radio and you have only visual indicators of your speed. ( and how many cars you pass / pass you I guess) |
Skippy Pocket GPS Verifier
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Sat Nov 13, 2010 8:31 pm Post subject: |
M8TJT wrote: | Skippy wrote: | Cameras won't take a photo unless your speed is constant.... | Where does that particular piece of urban myth come from  |
The cameras take a number of readings and if the speed is changing rapidly then it won't trigger because it's not sure it has an accurate reading.  _________________ Gone fishing! |
Guivre46 Frequent Visitor
Joined: Apr 14, 2010 Posts: 1262 Location: West London
Posted: Sat Nov 13, 2010 11:06 pm Post subject: |
Fellwalker wrote: | And don't forget the windscreen wipers operating off the vacuum so that they stopped when you accelerated. My Ford Pop used almost as much oil as petrol above 50mph. |
Right, it munched piston rings. Needed to replace them nearly every year - still have some scars. _________________ Mike R [aka Wyvern46]
Go 530T - unsupported
Go550 Live [not renewed]
Kia In-dash Tomtom |
M8TJT The Other Tired Old Man
Posted: Sat Nov 13, 2010 11:44 pm Post subject: |
Skippy wrote: | The cameras take a number of readings and if the speed is changing rapidly then it won't trigger because it's not sure it has an accurate reading.  | Presumably you are talking about laser hand helds. Fixed cams mostly use doppler CW radar to take continuous readings. I wonder how much you can alter your speed by in 300msec without standing your bike on its front wheel. BTW I did notice your wink |
aj2052 Frequent Visitor
Posted: Sun Nov 14, 2010 3:53 am Post subject: |
And nobody mentioned the sore thumbs from the starting handle Kickback. and my first was a Standard 12 or was it a 14 with kickboards for the passengers in sunny weather, you had to put your hand out the window to scrape the windscreen outside in the winter aswell as the inside and bank the pillar to make the old semaphores work, Oh happy days.even if thier was cameras you didnt have time to look for them. _________________ Moto G5s Plus, Sygic 17.4.8 |
Andy_P Pocket GPS Moderator
Posted: Sun Nov 14, 2010 8:05 pm Post subject: |
M8TJT wrote: | Skippy wrote: | The cameras take a number of readings and if the speed is changing rapidly then it won't trigger because it's not sure it has an accurate reading.  | Presumably you are talking about laser hand helds. Fixed cams mostly use doppler CW radar to take continuous readings. |
I tend to agree with M8TJT... I don't think a standard Gatso is that clever!
Also, I used to regularly see a biker who (just for a giggle) would go from a standing start at the traffic lights on the north side of Chiswick Bridge in London and then accelerate past the camera on the other side of the road, causing it to falsely trigger and flash the cars going past it on the right side.
The only time I ever got done by a camera (through sheer inattention), I was accelerating.... |
tomcat76 Lifetime Member
Joined: Aug 18, 2004 Posts: 100 Location: West London
Posted: Sun Nov 14, 2010 11:28 pm Post subject: |
Darren wrote: | SPECS is still something of a mystery. How many of the cameras are active at any one time is unknown and from conversations with the manufacturers, it appears that they are rarely all active and in some roadworks installs, not even connected!
Ah ha.... so that's why when I come down the M1 approaching Luton and you have that 15mile section of roadworks I am plodding along at a steady 50 and I get trucks wizzing past me and even faster are the car's... maybe they know which ones are not working, or are they in for a shock when they get their ticket...  _________________ Regards Steve :-) |
Darren Frequent Visitor
Posted: Sun Nov 14, 2010 11:51 pm Post subject: |
Indeed. I discussed this with a taxi driver who was taking me to Heathrow a while back. His company do a large number of airport transfers and he claimed the M3 SPECS had never resulted in a ticket. He was quite happy to drive through them at 70.
His comments were what prompted me to quiz the company at a trade show we went to and they as good as said they were rarely all configured or active. Of course I wouldn't expect them to admit that entire sections were inactive but when roadworks move along a motorway it's not hard to imagine that the SPECS setup may not always be configured or even powered  _________________ Darren Griffin |
spook51 Lifetime Member
Joined: Mar 26, 2004 Posts: 548 Location: East Midlands
Posted: Mon Nov 15, 2010 9:30 am Post subject: |
Surely that's true of any fixed camera Darren - that it may or may not be active, irrespective of type? |
Posted: Mon Nov 15, 2010 11:18 am Post subject: |
spook51 wrote: | Surely that's true of any fixed camera Darren - that it may or may not be active, irrespective of type? |
Not at all. Yes the old wet film GATSO's may not have a film in them but you can be darn sure they are set-up to work and wired for power. Same applies to all the other fixed camera types. The digital ones are always live.
The point being here that it was intimated that some of the road-works SPECS were not connected to anything, no data hook up, no power, nothing and were there only to serve as a warning. _________________ Darren Griffin |
Posted: Mon Nov 15, 2010 12:23 pm Post subject: |
I see what you mean. That could certainly be true of the Cat & Fiddle SPECS as discussed elsewhere - thanks for the clarification. |
Posted: Mon Nov 15, 2010 2:35 pm Post subject: |
Anyone got a camera with a night vision setting?
At least we could find out if the IR illuminators were switched on. |
Posted: Mon Nov 15, 2010 2:50 pm Post subject: |
Andy_P wrote: | Anyone got a camera with a night vision setting?
Worth a try, I've got a camera with night-shot mode using IR, will check. _________________ Darren Griffin |
