Pocket GPS World :: View topic - speed alert database
sailerman1951
PostPosted: Thu Nov 04, 2010 11:47 am    Post subject: speed alert database Reply with quote
Hi trouble accessing the speed cameras on my nuvi 490t, they download ok, and load on to my device but they do not appear on the maps, I have tried switching off the garmin database but nothing changes,
mike
PaulB2005
PostPosted: Thu Nov 04, 2010 12:12 pm    Post subject: Reply with quote
How are you loading them to the device?
Are you following the instructions here?
Have you enabled Custom POIs?
sailerman1951
PostPosted: Thu Dec 09, 2010 9:07 am    Post subject: speed cameras on garmin nuvi Reply with quote
have followed instructions to the letter, have also removed and re installed, they show up as custom POI, have tried de activating garmin ones and i just get no speed cameras at all
PaulB2005
PostPosted: Thu Dec 09, 2010 9:10 am    Post subject: Reply with quote
Are you testing this in the real world by driving or just looking at the map?
Best to test it by driving.
sailerman1951
PostPosted: Thu Dec 09, 2010 9:56 am    Post subject: speed cameras Reply with quote
Hi yes did a 100 mile run, only cameras that show are the garmin ones, switch those off and no cameras, used the database on my previous two units, one tom tom and a garmin with no problems
PaulB2005
PostPosted: Thu Dec 09, 2010 10:22 am    Post subject: Reply with quote
Hmm. There hasn't been a Garmin model the database doesn't work with so far and quite a few members have the 1490 and no compliants it doesn't work so far....
Just to check...
- you are downloading the Garmin POILoader database?
- you are located in the UK and you have chosen the UK database and not the European one?
- if you know the location of a camera if you zoom in on the map right up to it does it show?*
- you are using Garmin POILoader to install the speed camera database in Express mode?
- once you have loaded the speed camera database you are NOT then loading any further POI files such as Supermarkets and Petrol Stations etc?
* Not sure if you can still do this with the latest models...
sailerman1951
PostPosted: Thu Dec 09, 2010 12:41 pm    Post subject: speed cameras on garmin nuvi Reply with quote
seem to have tried most things suggested except zooming in to a camera, when installed if i open my garmin on the comp where should i find the cameras? and what will they be called? in POI i can find some but the file is very small
PostPosted: Thu Dec 09, 2010 12:49 pm    Post subject: Re: speed cameras on garmin nuvi Reply with quote
so they've installed correctly then. can you go to: settings / proximity alerts and make sure that 'custom poi' is ticked?
PaulB2005
PostPosted: Thu Dec 09, 2010 1:42 pm    Post subject: Reply with quote
All you will see is a file called POI.GPI in the Garmin/poi folder
Then they are loaded. However Garmin units only show you the POIs closest to your location hence the short list. I can't remember if it's the closest 25 POIs or if it's all POIs within 25 miles....
PostPosted: Thu Dec 09, 2010 2:17 pm    Post subject: Reply with quote
closest 25 (or maybe 40?) as opposed to within a certain radius.
22.064 (26 Jun 24)
