m4ttc Occasional Visitor
Posted: Thu Oct 21, 2010 11:23 am Post subject: Garmin 3790t POIs question |
I've loaded a few on such as Tescos etc ;-)
Quick question, should they show up in map mode ?
Cheers |
BAVC10 Lifetime Member
Posted: Thu Oct 21, 2010 4:28 pm Post subject: |
The custome POIs only show up when you are in very close proximity to them and the unit has "zoomed" in. Otherwise, no you don't see them as you pass by unless you select one as your destination.
There is some debate about why units for Asia have the user defined functionality to select whether and which POIs are displayed. _________________ DriveLuxe 51 LMT D - Firmware 6.70
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3 |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15155 Location: Bradford, West Yorkshire
Posted: Thu Oct 21, 2010 7:57 pm Post subject: |
also, make sure they are actually installed!!
Where to / extras / custom POI
for some reason they don't seem to install to the device (speed cameras at least, not tried normal pois yet) and you need to install to Micro SD card.
MaFt |
Posted: Thu Oct 21, 2010 8:06 pm Post subject: |
I have never had a problem loading POIs onto my 3790T - same process as for every other Garmin I have owned. I believe Windows 7 has some connectivity issues (I am using XP). I use the Speed Cams from this site and the POIs from a rather nice site GarminPOI.co.uk (when is the next update?) and POILoader to update. _________________ DriveLuxe 51 LMT D - Firmware 6.70
Posted: Thu Oct 21, 2010 10:01 pm Post subject: |
BAVC10 wrote: | I have never had a problem loading POIs onto my 3790T - same process as for every other Garmin I have owned. I believe Windows 7 has some connectivity issues (I am using XP). |
ah, must be Win7 issue then! it says they're installed but doesn't actually put them on. will try on mac before i finish the review of it!!
Quote: | I use the Speed Cams from this site and the POIs from a rather nice site GarminPOI.co.uk (when is the next update?) and POILoader to update. |
i know, i know, huge backlog and just haven't had the time unfortunately... paid work has to take priority!
MaFt |
Andy_P Pocket GPS Moderator
Posted: Thu Oct 21, 2010 10:25 pm Post subject: |
They're PAYING you?!?!?!? |
gatorguy6996 Frequent Visitor
Joined: Feb 16, 2008 Posts: 695 Location: Florida, USA
Posted: Fri Oct 22, 2010 2:07 am Post subject: |
MaFt, think I've read that "safely disconnecting" your 37xx with Win7 will sometimes (usually/always??) cause the software updates to fail flashing the device. Against all Windows recommendations, once you're certain any data writes should be complete, try just pulling the USB cable rather than unmounting the drive via Safe Disconnect. _________________ Garmin 1695 / 255 / 760 w/MSN - Droid w/Google nav + Navigon - Navigon 8100T - Dakota10 - GPSMap76C - GeoMate Jr. |
Posted: Fri Oct 22, 2010 9:27 am Post subject: |
Thanks.
Do they need to be installed onto a MicroSD card or can they go onto the device?
I have been downloading them onto my PC and uploading using the POILoader until.
I checked again and they are there but rediculously small and it seems you have to be zoomed in as far as possible to see them.
If I get the PGPSW Camera db, do I need to remove the garmin cameras ? If not will I get duplicate alerts?
Sorry for so many questions, I ve had integrated gps in last 6 cars
This is definately a massive improvement on them
Cheers |
Wazza_G Lifetime Member
Joined: Jan 10, 2006 Posts: 585 Location: Guildford (Regrettibly)
Posted: Fri Oct 22, 2010 9:38 am Post subject: |
I find that you need to delete the existing cameras from the unit to get the PGPSW cameras to appear, it's also best to put them on a MiSD card.
I've got (dad's actually) the 3760T which is virtually identical and it works perfectly like that. _________________ Be alert.. This country needs more lerts. |
Posted: Fri Oct 22, 2010 10:15 am Post subject: |
Wazza_G wrote: | I find that you need to delete the existing cameras from the unit to get the PGPSW cameras to appear, it's also best to put them on a MiSD card.
I've got (dad's actually) the 3760T which is virtually identical and it works perfectly like that. |
How d you remove the pre loaded garmin cameras?
Thanks |
Posted: Fri Oct 22, 2010 10:21 am Post subject: |
When the computer's connected to the unit, use My computer find the unit, then "Open" it and you'll find all of the folders inside, just delete (if you're happy to do so) or copy the folder to the computer (backup) the existing POI folder & replace it with an empty version of it.
You can the insert a MiSD card into the unit and then you can install any POIs to both or just the card for future use. _________________ Be alert.. This country needs more lerts. |
Posted: Fri Oct 22, 2010 10:27 am Post subject: |
Wazza_G wrote: | When the computer's connected to the unit, use My computer find the unit, then "Open" it and you'll find all of the folders inside, just delete (if you're happy to do so) or copy the folder to the computer (backup) the existing POI folder & replace it with an empty version of it.
You can the insert a MiSD card into the unit and then you can install any POIs to both or just the card for future use. |
Cheers, it makes sense. I thought the folder structure on the unit would be right protected. I could just rename it with a ! In front.
What size Micro SD is recommended?
Cheers |
Posted: Fri Oct 22, 2010 10:37 am Post subject: |
I've got a 4Gb card in mine at the moment, but I have tried a 8Gb one & that works too.
I don't know what the maximum "supported" size is though. _________________ Be alert.. This country needs more lerts. |
