Pocket GPS World :: View topic - Vent Mounts
Vent Mounts
SteveW
PostPosted: Thu Jul 29, 2004 11:23 pm    Post subject: Vent Mounts Reply with quote
Anyone out there got any experience of Vent mounts. The mount that came with my TT kit just does not hold the PDA securely in hot weather, must be something to do with the friction plate inside the holder. I have been looking at the magnetic "one click" version here.
Anyone got one of these or can recommend something else?
Steve
dunno
PostPosted: Fri Jul 30, 2004 2:56 pm    Post subject: Reply with quote
i used it for my phone but stopped using it as every time i took my phone away it was aways almost frozen from the air con , and doing that all the time can't be good for the appliance
TC
PostPosted: Fri Jul 30, 2004 3:59 pm    Post subject: Reply with quote
I use a vent mount clip with a compatible Bodit mount for my HP2210, and it really works well and looks great. I can highly recommend one of these high quality mounts.
Ipaq 2210
Fortuna Clip-on [Xtrac V2]
Tom Tom Navigator 3
Memory Map
SteveW
PostPosted: Sun Aug 01, 2004 12:16 am    Post subject: Reply with quote
Good point Dunno, I must say I have been using a window mount on one car, and a vent mount on my car without air conditioning. Has anyone used the magnetic mount though, does it secure the PDA sufficiently, how big is the plaate you stick on the back and does the magnetism cause problems.....? Confused
The Brodit mounts look a bit expensive.
Steve
spook51
PostPosted: Mon Aug 02, 2004 11:29 am    Post subject: Reply with quote
I use this vent mount in my Audi A4 with A/C. I made a holder for my Axim X3 from an aluminium case bought on E-Bay, I removed the front flap and ground off the hinges - much less bulky than most PDA holders. The stick-on magnet (3 x 2cm) sticks to the holder, not to the back of the Axim.
I've had no problems with magnetism though I only use my GPS on average a couple of times a week and of course the magnet isn't permanently fixed to the Axim.
It stays in place pretty well; it has only fallen off once but that was because the cable got wrapped round the gear stick - I have a Haicom 204S. I leave the quick release (the oval thing with the square 'loop' at one end) in place all the time as a holder for my phone when I'm not using GPS; the stick-on magnet fits in a similarly shaped cutout on the front of the quick release.
I've never had problems with cold air from the A/C affecting either Axim or phone. I thought is was excess heat that sometimes caused failure, I wouldn't have thought that air at a temperature comfortable for the driver should cause problems.
The complete kit included screen mount, two quick releases and four stick-on magnets so is quite versatile and, for £20, pretty good value.
xda
PostPosted: Mon Aug 02, 2004 1:21 pm    Post subject: Reply with quote
The only problem that can occur is producing condensation on the inside of the phone/PDA which could cause a short.
Graham.
Map: Europe V910.4892
Nokia 925 Windows 8
spook51
PostPosted: Mon Aug 02, 2004 2:23 pm    Post subject: Reply with quote
I hadn't thought of that, thanks Graham. I invariably have the vent to which the PDA mount is attached closed so I guss the risk is reduced (my wife reckons the air from the A/C dries out her skin...)
SteveW
PostPosted: Mon Aug 02, 2004 10:38 pm    Post subject: Reply with quote
Spook51,
How thick is the magnet?
Steve
spook51
PostPosted: Tue Aug 03, 2004 6:34 am    Post subject: Reply with quote
Including the sticky pad it's 1.5mm; the 3M sticky pad is thicker than the magnet itself.
SteveW
PostPosted: Tue Aug 03, 2004 11:48 pm    Post subject: Reply with quote
Thanks Spook,
Seems like a good option then.
Thumbs Up Steve
mrklaw
PostPosted: Wed Aug 04, 2004 10:57 am    Post subject: Reply with quote
kind of the opposite of my windscreen mount. Recently in the hot weather I put my PDA in and drove off. The PDA needed charging, so it was doing that, and then it popped up a dialog box saying ' the battery is getting too hot, so I've stopped charging for a bit'.
Very annoying while navigating, as you have to click a tiny 'OK' to make it go away.
It wasn't even that hot in the car.
ikesler
PostPosted: Wed Aug 04, 2004 3:01 pm    Post subject: Reply with quote
I am very happy with my mount from http://www.proclipusa.com/frameset.htm
Works great and fits perfectly for my car!
Ian
Kirium
PostPosted: Thu Aug 05, 2004 9:34 pm    Post subject: Reply with quote
I wouldn't want to trust my baby with a magnet Laughing
I did have a vent mount but frankly it was sh**te, not rigid at all, my pda wobbled about all over the place, I know the suspension on my car is stiff but everytime I went over a manhole cover the whole assembly wobbled Sad
I changed the vent mount (approx £6) for a smartclip (approx £15) which is absolutely superb -- it could be a part of the cars trim its that solid. I chose to put it over the centre air vents (the passengers can see whose talking Smile )and have been using it for about a year -- no problems with the AC at all...
Apple iPhone 5, Navigon, Brodit ProClip Mount
Fuego
PostPosted: Thu Aug 05, 2004 11:47 pm    Post subject: Reply with quote
I use a Brodit mount over the vent. Even when the air con is running at 16 degs C I don't think its a worry. Just not really cold enough, considering that in winter it can be below zero for quite some time before the heating kicks in.
The Brodit mount is rock solid. very impressed with these mounts. I have an Arkon mount for hire cars, when I go abroad, and these are not so solid.
spook51
PostPosted: Sat Aug 07, 2004 9:52 pm    Post subject: Reply with quote
I've just completed a Somerset - North Wales - Somerset round trip using the magnetic vent mount with no problems at all. My Axim was held securely at all times, didn't wobble, wasn't affected by the heat or the A/C and TT3 directed us door to door with great precision.
22.071 (03 Jul 24)
