Pocket GPS World :: View topic - Clarification to some of my 1K queries
Gee-Pee
PostPosted: Mon Oct 11, 2010 1:12 pm    Post subject: Re: Clarification to some of my 1K queries Reply with quote
1ee wrote:
You can create a new account if you wish but there is no need to if you are using oneTT device the TT system (sorry I'm not techie) will pick the device up and all should be well. The system IDs by serial number not email address login.
If you use more than one TT device then it would be preferable to create a email/login for each device.
Mobile camera info is fed to the 1K without any user intervention once a GPS signal has been received. Fixed camera info will be via the web when enabled.
The reason I see three listing for TT live HD under service is because one is embedded into the unit - but not to worry I have 1 year of HD.
Lee
Hi 1ee - I assume that this is an update to your thread, HERE and that you have been talking to TT support Question
Gee-Pee
Lifetime member PGPSW - time rapidly decreasing
PostPosted: Mon Oct 11, 2010 7:43 pm    Post subject: Re: Clarification to some of my 1K queries Reply with quote
(My colouring.) The correct word to use is obligatory.
You can NOT register more tham one device on one single account/email/login.
Gee-Pee
PostPosted: Mon Oct 11, 2010 8:17 pm    Post subject: Re: Clarification to some of my 1K queries Reply with quote
That is my understanding too Confused But, as 1ee got that from TT support, I assumed either he, misunderstood, or more likely, he was given the incorrect information. In view of regular changes from TT, it could well be correct, particularly as he states that it is the device number that is the ID and not the email address.
Graham
Gee-Pee
dhn
PostPosted: Mon Oct 11, 2010 8:20 pm    Post subject: Reply with quote
I think Home 2 is now screwed up.
One of the few things is did correctly was to keep information for separate units and associated user_ids (emails) properly.
Not for me (and some others) anymore.......since the change to TomTom's website.
Gee-Pee
PostPosted: Mon Oct 11, 2010 8:24 pm    Post subject: Reply with quote
And there speaks someone who knows Cool
Gee-Pee
PostPosted: Mon Oct 11, 2010 8:50 pm    Post subject: Reply with quote
Groan!! So, not content with bringing out a dodgy new device and a dodgy new Home, they are broadening their horizon to screw what little functionality more or less did work previously. How long before my devices become unusable?
lbendlin
PostPosted: Mon Oct 11, 2010 9:53 pm    Post subject: Reply with quote
here's a little something for the tinkerers. Assume you're on Windows, and have the 1xxx connected. Run "ipconfig" in a command line window (run...cmd...ipconfig) and then think about the result.
Looks like the 1xxx has a web server of sorts, and you can push and pull data if you know the right addresses. Might be worth to let a packet analyzer run around the RNDIS interface. http://www.snapfiles.com/get/msnetmon.html
Lutz
TomTom/TeleAtlas NAVTEQ
Guivre46
PostPosted: Mon Oct 11, 2010 11:08 pm    Post subject: Reply with quote
This sounds the final straw. Anymore details dhn? Is there a way round it?
Mike R [aka Wyvern46]
Go 530T - unsupported
Go550 Live [not renewed]
Kia In-dash Tomtom
dhn
PostPosted: Mon Oct 11, 2010 11:13 pm    Post subject: Reply with quote
When I connect to Home 2 (now) with unit X, it does show the proper model on the bottom of the screen. But the log in field at the top which normally shows the appropriate email address for unit X, now is empty.
If I then proceed to 'update my unit', I get the screen saying the email address does not match the unit and proceeds to show me the email address associated with unit Y. One of the options provided is to log in with the relevant email address for X (which it no longer remembers).
Once I do that, then things proceed properly.
Guivre46
PostPosted: Mon Oct 11, 2010 11:26 pm    Post subject: Reply with quote
So not terminally screwing up each unit with data meant for the other [even quickfix is a different version for each of my two]? Just the tedium of adding another step to the Home process.
Thanks for warning, will watch it closely.
Kia In-dash Tomtom
22.062 (12 Jun 24)
