Pocket GPS World :: View topic - How do I unloop a route?
gjwcarsaig
PostPosted: Sun Oct 03, 2010 3:14 pm    Post subject: How do I unloop a route? Reply with quote
I tried to find out how to unloop a route, but started to think it must be impossible because I couldn't find out how, and the user guide was no help whatsoever.
However today while modifying a route the option to unloop appeared on screen, but when I tried to access the option again I failed.
I'd like to find out if this feature is available, as it would save me some time.
Thanks, Gavin.
BigPerk
PostPosted: Sun Oct 03, 2010 8:19 pm    Post subject: Reply with quote
IF I understand you correctly, can you not just delete the waypoint where the loop rejoins and then adjust as you want?
(Navigon 70 Live, Nuvi 360)
RavingDave
PostPosted: Sun Oct 03, 2010 10:43 pm    Post subject: Reply with quote
You need to go into 'edit route', and select 'edit route map'.
Then move to the start / finish point of the loop, and press the joystick button. The Satmap will then ask you if you want to open the route.
If you try to delete the start / finish point it will just get rid of the waypoint, and move the start finish point to the next waypoint, but still as a closed loop.
gjwcarsaig
PostPosted: Mon Oct 04, 2010 10:30 am    Post subject: Reply with quote
Thanks RavingDave. That's solved my problem.
I must have managed to do this by accident, and then couldn't figure out what I'd done.
As you said I was trying to do it by deleting the starting waypoint, but didn't realise that the route would remain in a loop.
22.123 (18 Dec 24)
