Pocket GPS World :: View topic - RDS Traffic not working - TomTom Go 730
razor302
PostPosted: Fri Oct 01, 2010 10:36 am    Post subject: RDS Traffic not working - TomTom Go 730 Reply with quote
Hi there I put a comment on one of the forums with regards to my RDS Traffic not working and was advised to make a new topic, which I have.
This is what I was told to do:
Why not create a new thread about this RDS issue as they certainly haven't pulled the plug on the RDS TMC Traffic system, what they did was release a map with some data files that Home incorrectly installed to the device rendering the Traffic useless - If this is whats wrong I am sure we can soon fix this little issue for you - Mike
I have not had traffic RDS working on my Go for many months and do miss it as I travel a lot throughout the UK.
When I plug the RDS cable in nothing happens no bar up the side, nothing, like it used too.
I even took the SD card out etc then replaced it and it worked then went off gain.
Is there any way I can ever get this working again, as I think my machine could now be a little corrupt and a full rest would may not be a bad idea, however I am unsure how to go about a complete re-set in case I cannot get it working again.
Kind Regards
Ray
razor302
PostPosted: Fri Oct 01, 2010 10:38 am    Post subject: Is it in the correct section?? Reply with quote
I'm not sure if this is in the correct forum when I looked at it. If not could somebody move it to the correct one for me please?
Regards Ray
PostPosted: Fri Oct 01, 2010 11:13 am    Post subject: Reply with quote
Ray, I have moved the thread to somewhere more applicable, can you tell us what version of Navcore is installed to the device and the map version. You can find this information by starting up the device and tapping the sat strength meter lower right corner, then tap the sat strength meter on the right of the screen about one third of the way down, the resultant screen will have the information I am interested in.
Finally what type of RDS receiver are you using does it have a round plug or a Mini USB plug on the end that connects to the TomTom - Mike
Edit to add can you give me the information from the device with the SD card fitted then repeat it with the SD card removed (just seen the other thread on the same subject) lets keep it all in this thread please - Mike
razor302
PostPosted: Fri Oct 01, 2010 11:51 am    Post subject: Reply with quote
Thanks a lot for your help Mike,
The details are as follows:
It says version 8.351(9982/090518) OS:315187
The Map version is: v835.2419
The type of RDS is a round plug in type, similar to an earpiesce connector which is a seperate connector on the unit.
It used to work fine till one day I upgraded the firmware as requested.
Kind Regards
Ray
dhn
PostPosted: Fri Oct 01, 2010 11:56 am    Post subject: Reply with quote
Where are you located, Ray?
razor302
PostPosted: Fri Oct 01, 2010 12:02 pm    Post subject: Reply with quote
Liverpool UK
PostPosted: Fri Oct 01, 2010 12:07 pm    Post subject: Reply with quote
Connect the device to the PC and use Windows Explorer to view the contents of the drive letter associated with the device, locate and open the Western_Europe map folder, in here will be two files that I want to know the file size associated with them:
tmcodes.dat
traffic.dat
These are the two files that Home messed up when installing a map a while ago so its worth checking these first before we move on to other ideas - Mike
razor302
PostPosted: Fri Oct 01, 2010 12:37 pm    Post subject: Reply with quote
Mike,
Traffic.dat is 1kb
tmacodes.dat 6,228
Regards
Ray
Guivre46
PostPosted: Fri Oct 01, 2010 3:18 pm    Post subject: Reply with quote
On my device tmccodes is 1000kb and traffic.dat is 4kb, so something is not correct. Just been out with my rds-tmc usb and worked OK.
Afterthought: on the rare occasion it plays up [usual symptom is it cannot identify its exact location], I've found it needs a factory reset. The soft reset advised on various forums does not seem to fix it on my device. Just remembered you have the jack-plug version, so maybe I'm not helping...
Mike R [aka Wyvern46]
Go 530T - unsupported
Go550 Live [not renewed]
Kia In-dash Tomtom
PostPosted: Fri Oct 01, 2010 3:53 pm    Post subject: Reply with quote
The Western_Europe map folder has a considerably larger tmccodes.dat file than the UK&ROI map folder which will explain the differences noted above.
What's listed in your gns folder on the device - Mike
Guivre46
PostPosted: Fri Oct 01, 2010 4:38 pm    Post subject: Reply with quote
gns = TmcEApi.so at 72Kb. I'm on a mac so not sure I could delve further into an 'so' file
Kia In-dash Tomtom
alan_sh
PostPosted: Fri Oct 01, 2010 6:34 pm    Post subject: Reply with quote
I think your cable has gone.
Alan
razor302
PostPosted: Fri Oct 01, 2010 8:04 pm    Post subject: Reply with quote
No the cable works fine on my friends TomTom Go 720 so I know for a fact thats ok.
It is definately something to do with the last firmware update I completed as it never worked after that !!
Is there anyway I can start my Tomtom from complete scratch like I would when I format my PC and if so do you think that would work?
Regards
Ray
razor302
PostPosted: Fri Oct 01, 2010 8:10 pm    Post subject: Reply with quote
Hi Mike,
In the gns file there is the following:
gnsdata = 17kb
and
TmcEApi.so = 69kb
Regards
Ray
AliOnHols
PostPosted: Fri Oct 01, 2010 9:39 pm    Post subject: Reply with quote
razor302 wrote:
Is there anyway I can start my Tomtom from complete scratch like I would when I format my PC and if so do you think that would work?.....
Did you make a Windows Explorer back up when you first got your TT?
Garmin Nuvi 2599
SatMap Active 10 & 20.
23.054 (28 May 25)
