Pocket GPS World :: View topic - Restoring Backup
Restoring Backup
Goto page Previous  1, 2
PostPosted: Thu Sep 30, 2010 6:10 pm    Post subject: Reply with quote
Excellent news. (if anyone's wondering I found a copy of a similar version to what was anted)
Now don't forget to make another backup straight away!
Oh, and can I have a pint of Landlord instead? Most Guinness seems a bit cold for my liking these days. Cheers!
dhn
PostPosted: Thu Sep 30, 2010 7:39 pm    Post subject: Reply with quote
Want to share so all of us can learn from your solution?
PostPosted: Thu Sep 30, 2010 8:37 pm    Post subject: Reply with quote
Let it stand on the bar for at least five minutes for the perfect temperature.
As for an early Navcore for the XL IQ Live This is one such example, although there are others, this is the earliest I can find for the device in question - Mike
PostPosted: Thu Sep 30, 2010 9:01 pm    Post subject: Reply with quote
Here's what I PMed to Paddy
Hi Paddy.
I've had a damn good search and can't find any download link for v8.420 or even any reference to it.
However, I have found v8.419 if you want to try that.
Download the file from here:
HERE
That will produce a "cab" archive file, and there are two ways to continue from here....
I think you can put the .cab file into Home's program folder (C:\Documents and Settings\username\My Documents\TomTom\HOME\Downloads\complete\program), but you need to REMOVE any newer version from there or Home will ignore it.
But I try to avoid Home as much as possible, so I would go for the manual way to install it. It will be a little tricky but here's the way I would do it.
First you will need a program such as WinRar to de-compress the .cab file (free download of WinRar from HERE).
Once WinRar is installed, you should end up with new items on the right-click menu when you click on the downloaded .cab file.
So, right click on it and select "Extract to 8.419....." (Don't just use "Extract here" or you will end up with files everywhere!).
That should produce a single folder containing a set of sub-folders (with the same names as some of the ones on the TomTom itself) and a bunch of loose files.
You need to copy and paste those files into the same places on the XL, replacing the versions already there and I can never remember how good Windows is at replacing files in sub-folders with older ones, so I cop-out and do it manually folder by folder!
dhn
PostPosted: Thu Sep 30, 2010 10:04 pm    Post subject: Reply with quote
Thank you Andy.......
Page 2 of 2
22.064 (26 Jun 24)
