Pocket GPS World :: View topic - Navcore 9.054 What is actually different?
Goto page Previous  1, 2, 3
PostPosted: Sun Sep 26, 2010 9:27 pm    Post subject: Reply with quote
Sorry for late reply, I've been away.
I would always suspect mapsettings.cfg in cases like this. We KNOW it often isn't compatible between different software versions and even though people have found get-rounds which SEEM to make it work (such as using "Operate my Go" in Home to add a new favourite) I take the stance that if you are getting ANY odd behaviour, it is best to just delete it, allow the new system software to create a fresh one and then enter your settings again.
A bit boring to do, but worth it to eliminate that possible reason for any problems.
MrT
PostPosted: Mon Sep 27, 2010 8:01 am    Post subject: Reply with quote
I re-created the mapsettings.cfg file recently after the Live Services problems and the upgrade to 9.058 & 8.55 maps.
If you have a lot of data/settings you could always backup then delete the mapsettings.cfg file and just let it create a new file then test it out without re-entering all your settings. If the problem has cleared this points to the file so then re-enter all your settings. If the problem is still there, it is probably not the file so you can restore the original from backup with the settings it contains.
Drivelux
Page 3 of 3
22.064 (26 Jun 24)
