Pocket GPS World :: View topic - TomTom Wont Start
TomTom Wont Start
x7r3me
PostPosted: Fri Aug 27, 2010 1:36 pm    Post subject: TomTom Wont Start Reply with quote
Hey guys. Yesterday I plugged in my TomTom XL to TomTom Hme and it was searching for updates (GPS fix / Traffic etc) but I pulled out the usb cable without ejecting.
Now my TomTom doesn't boot up at all.
I have tried all the reset methods (paper clip).. 15 seconds - 30 seconds.. Hold down power button.. (held it down for more than 5 minutes!) and still nothing.
Plugging in TomTom via usb doesn't work as it is not recongised.
It is 100% charged..
What do you think is wrong with the device? It has been working for over 4 years... and yesterday Bam.. it went...
I have asked TomTom to repair it.. I need to send it in and they will quote me
Please Help me... thanks guys... look forward to your replies.
PostPosted: Fri Aug 27, 2010 1:40 pm    Post subject: Reply with quote
Plug the unit in to your PC, reset the TomTom then let it boot up as far as is possible, if Home starts up shut Home down as its not needed for this.
Start Windows Explorer on the PC and look through the drive letters it lists, can you see one that applies to your TomTom? If so click it to open the drive, can you now see files and folders?
If you can check the above and report back we can then prescribe further action to take - Mike
x7r3me
PostPosted: Fri Aug 27, 2010 2:33 pm    Post subject: Reply with quote
Plugging it into the PC only makes the Green LED charging light come on.. nothing else happens... it is not reconsigned by the pc as the device does not boot. Otherwise I could have just deleted all the files on he TomTom and started again but since the device does not boot and tomtom home wont recognise it because of that... I cannot do anything.
As mentioned in my first post I have tried all the methods...
many thanks
x7r3me
PostPosted: Fri Aug 27, 2010 3:23 pm    Post subject: Reply with quote
Someone told me to use Clear flash
http://uk.support.tomtom.com/app/answers/detail/a_id/6178/?locale=en_GB
How would this help if my TomTom wont boot up?
Look forward to your replies.
thanks guys
PostPosted: Fri Aug 27, 2010 3:27 pm    Post subject: Reply with quote
If it won't boot up then clear flash won't be any use, get an RMA code and send it back for a repair quote - Mike
Guivre46
PostPosted: Fri Aug 27, 2010 4:10 pm    Post subject: Reply with quote
Did you actually do a reset whilst it was plugged in to your computer?
Mike R [aka Wyvern46]
Go 530T - unsupported
Go550 Live [not renewed]
Kia In-dash Tomtom
x7r3me
PostPosted: Fri Aug 27, 2010 4:24 pm    Post subject: Reply with quote
Yep.
1. Plug TomTom to PC via usb cable.
2. Greed LED charging light comes on.
3. I try to turn devivce on by holding the power button on for around 1 minute.
Nothing.
4. Use a paper clip to hold down reset button for 1 minute.
5. Try turn on using power button.
Nothing.
6. Hold down power button and reset button (using paper clip) together for 1 minute.
Nothing.
I really have tried everything. Is there anything else I can do guys? Thanks
dhn
PostPosted: Fri Aug 27, 2010 4:36 pm    Post subject: Reply with quote
Ask Mikealder here to post his guide for the battery removal of your unit, or close to it. Nothing else to lose.
PostPosted: Fri Aug 27, 2010 6:18 pm    Post subject: Reply with quote
As you have stated this "XL" has a reset switch I assume thats a hardware reset switch in the base so it shoulde also have an SD card slot, is there a memory card in the SD slot in the base of the device?
If not simply copy your back up to a memory card of sufficiant capacity and insert it to the slot and then try switching the device on, although I am starting to think that perhaps the reset switch is broken causing this problem (device in reset all the time due to the switch stuck in which is something that used to affect the x10 series) - Mike
x7r3me
PostPosted: Fri Aug 27, 2010 7:20 pm    Post subject: Reply with quote
Hi. You are correct in saying that there is an SD card. I do not have an SD card in the unit at the moment or ever for that matter... but I will try and copy a backup to a spare SD and see what happens.
I also read about the reset switch being stuck problem.. but when I use the paper clip I can here the 'clicking' signalling the switch is going from the up position to the down position meaning it isn't stuck...
Am I correct in saying that my reset switch is still intact or could there still be a problem with it?
Many thanks for your help guys
PostPosted: Fri Aug 27, 2010 7:24 pm    Post subject: Reply with quote
Try the SD Card route first as thats a nice easy way to recover a dead device if the internal Flash memory has fried itself, if that fails though AFAIK the only option is a return to TT or consider the purchase of a newer unit (probably work out around the same price as the repair TBH) - Mike
22.062 (12 Jun 24)
