jackbarry Lifetime Member
Joined: Mar 26, 2010 Posts: 172 Location: Wilmslow, Cheshire
Posted: Fri Aug 20, 2010 3:19 pm Post subject: |
I have just read the whole of the GO940-No Live Services thread and I see there that:
Andy_P wrote: |
Yes, they have made a cock-up. But the same version of software DOES work on the x50 and XL models and also on most x40's on mainland Europe. |
Well it certainly doesn't work on my GO750-NO LIVE!
Also Jon Honeyball (PCPRO) twittered that a fix is coming. Is that only for x40s? Does anyone know anything new?
Still totally fed up! jack
(Edited to sort out quote) |
Andy_P Pocket GPS Moderator
Posted: Tue Aug 24, 2010 12:02 am Post subject: |
jackbarry wrote: |
Sorry to hear that. The fact remains that MOST x50 models were unaffected (mine wasn't). |
Posted: Fri Aug 27, 2010 3:54 pm Post subject: |
Ok folks here's my latest attempts to solve the issues around v9.054 of the App and v850.2802 of the Maps:
Yesterday I spent quite a long time following TT's instructions viz - I firstly installed the new v2.7.6.2056 of TT HOME (that was a surprise to find a new version upon logging on) on the internal J: drive and successfully installed v9.054 of the App;
I then had to drive out with the 750 to get a GPS signal and it took quite a while for LIVE TRAFFIC to become connected but then to my delight everything seemed to work fine - the unit accepted any routing I gave it;
I then came home and logged on the SD K: drive and upgraded the Maps to v850.2802 (note I did not delete the old version first as TTHOME said it would upgrade) and drove out again with the 750 to get a GPS signal and everything seemed to be working until I stopped and tried to load in a route. The unit then crashed to a blank screen and reset itself. I have tried all possible ways since to input a route but it crashes every time.
So, in summary I have succeeded in loading the new App and HOME but there must be some incompatibility between 1 or both of them and the Maps! Incidentally in addition to the 2GB Maps folder there is another new small maps folder which only contains the file Europe_2Gb.tlv
I have asked TT what to do next but in the meantime should I reformat the SD card and reload my old Maps?
Any advice welcome, jack. |
zardoz Lifetime Member
Posted: Sat Aug 28, 2010 10:42 am Post subject: |
The one thing that causes my 950 LIVE to do this is to install the POI updates from Home. As long as I don't install those, I have a happy stable unit.
The moment that those POI updates get on to it, it does exactly the same as yours.
YMMV as always.
Z |
Posted: Sat Aug 28, 2010 12:21 pm Post subject: |
Thanks Z for your response I will try some deletions as well as other desperate things I am trying.
Does anyone know what a .tlv file does? Can I delete it?
Err, what does YMMV mean?
jack |
dhn Frequent Visitor
Joined: Oct 08, 2007 Posts: 2544 Location: Toronto CANADA
Posted: Sat Aug 28, 2010 12:42 pm Post subject: |
YMMV = Your mileage may vary
The .tlv file is really not that necessary. It's just used by TomTom to provide a description of the matching file. _________________ David |
Posted: Sat Aug 28, 2010 10:22 pm Post subject: |
... but why would you want to delete it?
It's not doing any harm or taking up any space and 'Home' finds it useful. |
Posted: Sun Aug 29, 2010 2:20 am Post subject: |
I should have said 'vital'. I wasn't implying that it be deleted necessarily. _________________ David |
Posted: Sun Aug 29, 2010 11:15 am Post subject: |
Sorry David, my reply wasn't aimed at you
Just wondering why Jackbarry was keen to delete it when it's such a tiny file. |
Posted: Wed Sep 01, 2010 8:34 pm Post subject: |
Hi folks,
Hurrah! My 750 GOLIVE is working again! After hearing about the new Maps I decided to completely clear out everything off my 4GB SD card and downloaded the new v855.2885 Europe (uncluding Turkey & Russia) onto it. Hey presto after resetting and then waiting about 15mins for the LIVE to update it all seems to be OK. The big test will be at the weekend.
So, I now have v2.7.6.2056 of HOME; v9.054 of the App and v855.2885 of the Maps.
Fingers crossed that I don't have to mess about with it any more.
Thanks for all the reponses on here,
Best regards, jack |
newsagent Lifetime Member
Posted: Thu Sep 02, 2010 2:11 pm Post subject: |
I have had horrendous problems since updating my 750 about a month ago. No live services, touch screen slow to respond which is extremely frustrating.
I have tried various drastic fixes and workarounds with no luck. I tried the TomTom "fix" for the x40 but it just re-installed the v9 software again.
I have a 4gb card so I deleted everything on the card and the unit. Installed the software using home just on the unit with no card inserted and then put the map on the unit but it still the same.
Finally bit the bullet and emailed TomTom and they suggested factory reset. I have tried this and still the same. Emailed tomtom again and waiting for a reply.
I have noticed though my subscription is now valid untill 31/01/2012 instead of 27/02/2011 although that's not much help if I can't get any service
I have been really disappointed with the live services overall, which is a shame because it is a nice unit.
Why do TomTom get so much wrong? |
Posted: Thu Sep 02, 2010 5:34 pm Post subject: |
Newsagent,
If you want to try what I did here it is:
1) Make a Windows Explorer backup of your internal & SD card drives;
2) Delete everything off the drives – & only if you want to, do a full format of each drive;
3) Connect the 750 to your PC;
4) When offered, download the new version of TTHOME v2.7.6.2056 onto the internal drive;
5) Then goto Update my Go and download v9.054 of the Application & everything else that you want except the Maps onto the internal drive;
6) Change device onto the SD card and then again Update my Go and download the new Maps v855.2885 onto that.
7) Close TTHOME and go out to get a GPS signal and wait for the TRAFFIC LIVE to update itself – this can take upto 20mins.
Fingers crossed, it worked for me after almost a month of hassle and numerous emails to & fro to TT and here.
jack |
Posted: Thu Sep 02, 2010 8:40 pm Post subject: |
jackbarry wrote: |
4) When offered, download the new version of TTHOME v2.7.6.2056 onto the internal drive; |
Home should never be installed on the Go itself, you install it on your PC!
When you first get a TT it often has an installer for Home on the internal memory, but it isn't Home itself. Even using that installer, the program itself will go on your C: drive by default. |
Posted: Thu Sep 02, 2010 11:32 pm Post subject: |
Thanks Andy_P for pointing that out. I hope that newsagent gets lucky. I certainly wouldn't want anyone to go through all of the hassle I have had with my 750 over the last month.
When it's working I really like it so I won't be looking for any upgrades, hopefully for some time to come.
Regards, jack. |
Posted: Fri Sep 03, 2010 3:09 pm Post subject: |
Thanks jackbarry, I've done all of what you've done and still no services.
Just had another response from TomTom after the factory reset didn't work and they suggested deleting and re-installing the application again even though I have told them I have already done it. Still I tried it again with no luck.
The email from them gives a link to respond if the problem is not resolved and surprise, surprise, the link is broken!!
I understand the x40 owners are being offered v8 when they connect to home.
Is there any way I can get back to the previous version, a fresh install, not one from a back up? |
