Pocket GPS World :: View topic - TT 930 Computer Voices problem
GNR
PostPosted: Fri Aug 13, 2010 9:37 pm    Post subject: TT 930 Computer Voices problem Reply with quote
Sorry if this question has already been asked but my google search came up with no answers and the worse than useless TT support were no help at all and didnt even reply to my email!
Recently I noticed my TT 930 that has worked well since I got it has developed a fault
I no longer have the function available to speak an address, the icon is now missing
I can download 2 Computer voices but when tap test there is no sound, so consequently no POI warnings spoken.
and last I can no longer get a signal for TMC its always searching no green circle, nothing has changed aerial wise.
I have a full backup done through explorer and am quite familiar with file shifting
My unit uses an SD card the required spec fopr the TT and all my files are on the SD card.
Is there any of you guys who can help please I know there is more knowledge here than at TT tech support.
Thanks in advance
Steve
dhn
PostPosted: Fri Aug 13, 2010 9:43 pm    Post subject: Reply with quote
Start with the easiest attempt to correct......
Restore (using Explorer) your backup.
PostPosted: Fri Aug 13, 2010 9:46 pm    Post subject: Reply with quote
What is the folder size for the LoquendoTTS folder on the SD card and the LoquendoTTS folder on the built in flash memory? - Mike
GNR
PostPosted: Fri Aug 13, 2010 10:00 pm    Post subject: Reply with quote
Hi Mike
The LoquendoTTS folder on my SD card is 91.4 MB on Disc
on the built in memory its 32KB on disc
Thanks for the quick replies chaps
GNR
PostPosted: Fri Aug 13, 2010 10:42 pm    Post subject: Reply with quote
I copied the larger folder over and replaced the smaller one and now I get computer voices.
So I guess the only function not working now is the spoken command feature when entering an address.
dhn
PostPosted: Fri Aug 13, 2010 10:56 pm    Post subject: Reply with quote
In the asr folder, check that there is a text file called support_asr.dat with only a 1 in it, no quotes, nothing else.
Also, make sure it really isn't there as support_asr.dat.txt (in other words, have your folder settings to show extensions for known file types).
PostPosted: Sat Aug 14, 2010 7:40 am    Post subject: Reply with quote
You had a LoquendoTTS folder on both the card and the built in memory, probably caused by the Navcore update being installed to the card when it should have gone on the device. You should only ever have a single LoquendoTTS folder and it needs to be on the same storage medium as the Navcore software is stored.
In addition to the suggestion from dhn make sure that the cspeech_GBR.dat file is in the Western_Europe map folder - Mike
GNR
PostPosted: Sat Aug 14, 2010 4:54 pm    Post subject: Reply with quote
Hi Guys thanks for your continued help with this.
Dhn I have checked for the support_asr.dat.txt in the location you suggest and there is no file of this name in there
Mike I have checked for cspeech_GBR.dat file in the Western_Europe map folder and its is there.
Any suggestions how I can get the support_asr.dat.txt file that Dhn talks of please.
Steve
GNR
PostPosted: Sat Aug 14, 2010 5:10 pm    Post subject: Reply with quote
Hi Guys
An update I managed to get the support txt file you mentioned now planted in the ASR folder now working!
Thanks very much to you guys I now have a working TomTom again.
I really appreciate your help
PS dhn, just got back from working for 2 weeks staying downtown Toronto...had a great time there people are great!
dhn
PostPosted: Sat Aug 14, 2010 7:05 pm    Post subject: Reply with quote
Glad you got it sorted.
Yeah, for all its faults, Toronto isn't a bad place as large cities go......
