Pocket GPS World :: View topic - Garmin Voice Warnings
mishmash
PostPosted: Tue Aug 10, 2010 12:30 am    Post subject: Garmin Voice Warnings Reply with quote
I have been using this database for a few years for my TT 700 GO and had the voice alerts on about a year or so. I only put them on my unit once and have worked spot on even when I update cameras. I allways use the UK speed zoned version.
I have also got a Garmin Zumo 550 and loaded the cams plus voices on to the unit with PIO Loader as instructions. Unchecked the garmin speed can box in unit. All worked ok except my TT GO gives me a voice warning evertime for a mobile postion and my Zumo gives me a voice warning for some and just a ping alert for others.
Is it the way I have loaded it as I could miss the ping when on the bike as I do not watch the screen.
I updated the cams on the Zumo and lost voices at one point. I reloaded cams and voices onto same folder and reloaded into unit and worked again so I asume that you have to add the voices everytime you update with the garmin, Is this correct?
Hope someone can make sense of my long winded post and put me in the picture as I am not a tecno buff.
PostPosted: Tue Aug 10, 2010 2:02 am    Post subject: Reply with quote
whenever POILoader updates your device it first clears any existing POIs from the device. i.e. for Garmin's you MUST install every file, every time!
the best way to do this is to keep a folder on your computer specifically for POI Loader to use. then any new POIs will overwrite the old ones in the folder and THEN you upload using POILoader.
Hope this makes sense
22.064 (26 Jun 24)
