Pocket GPS World :: View topic - TomTom V3 Possible Bug...
SpeedCam
PostPosted: Tue Jul 27, 2004 9:18 pm    Post subject: TomTom V3 Possible Bug... Reply with quote
Having used both TT V1 & 2 I've been experiencing a problem with TT V3 that I don't think exists in previous versions.
The problem started when I was driving home and the Navigator screen was showing all the correct directions and island exits etc etc, but I was continually being told to do a u-turn. As a result I though I'd exit TT and noticed that there was another version of TT running in the back ground but with a different route.
I also experience slowness, and when I've checked the running applications there was multiple version of TT running.
I'm sure there should be a very simple check at startup time that ensures that there isn't a version of TT already running, thus removing this problem.
Mearns
PostPosted: Tue Jul 27, 2004 10:53 pm    Post subject: Reply with quote
I've had a similar experience - map showing the correct route but the voice commands relate to some other destination. Must admit I didn't troubleshoot it so can't offer any views on what might have happened. Don't think in my case there could be multiple TTN versions running as I installed TTN3 after a hard reset.
Tony
nuvi 2460LT plus Brodit mount
xda
PostPosted: Wed Jul 28, 2004 8:56 am    Post subject: Reply with quote
I don't think it is a bug as such. I start TT from button 2 on the XDA and have a couple of times double pressed it and got 2 copies of TT running.
Just tried it on the cradle and managed to get 3 copies running on the 4th it came up insufficent memory available. It would be better if TT wasv able to detect that it was already running.
Graham.
Map: Europe V910.4892
Nokia 925 Windows 8
Mearns
PostPosted: Wed Jul 28, 2004 11:48 am    Post subject: Reply with quote
That makes a lot od sense, Graham - I also start TTN3 from a hardware button and I could well have been playing around with different routes before I went on the road. It's possible that unknowingly I had double launched it as you say. It's only happened the once in 12 months of using TTN.
Tony
iancjc
PostPosted: Wed Jul 28, 2004 4:04 pm    Post subject: Reply with quote
I've had this happen when calendar is open and ttn3 won't start - thinking I've not pressed it correctly I give another jab or 6 and then remember calendar is open - closing calendar causes all the instances of ttn3 to open and at least one will give you voice instructions to your previous destination (the one it was set to go to - hence the U turn instruction as you drive away from it) - whilst the on screen map will guide you as expected.
the most I've had running was 8 ttn3's! - very impatient that day - hopefully they will correct this soon.
Ian
TTN6.03 tomtom 7.xx (one)
SpeedCam
PostPosted: Wed Jul 28, 2004 7:24 pm    Post subject: Reply with quote
Yes this is exactly the problem, a button assigned to start TT, a simple code change to check to ensure another version is not already running would solve this. I cannot see any reason why you would want two copies of TT running at the same time?
23.015 (29 Jan 25)
