Pocket GPS World :: View topic - Kenwood DNX 9260 BT No Voice Prompts
rhd4609
PostPosted: Wed Jul 28, 2010 5:28 pm    Post subject: Kenwood DNX 9260 BT No Voice Prompts Reply with quote
Embarassed
I have downloaded the speed camera database and the voice prompt.
Cameras OK but no voice prompt (I am in Spain) also can I dowload the decent ICONS to show the cameras rather than the small thing I get now and the beep is almost unhearable can I adjust
Robert
PaulB2005
PostPosted: Wed Jul 28, 2010 7:29 pm    Post subject: Reply with quote
It appears from previous attempts that the Voice are not supported on the Kenwood units.
If you can use the icons it should just be a case of replacing the ones in the download with the new ones.
cjay2412
PostPosted: Wed Jul 28, 2010 8:57 pm    Post subject: Reply with quote
it is possible but they dont make it easy files must be in mono wave format
you also need to add sox.exe to the same folder as poiloader and the files need to be called the same
i.e
gatso.csv
gatso.wav
hope this helps
JSparrow
PostPosted: Wed Jul 28, 2010 8:59 pm    Post subject: Re: Kenwood DNX 9260 BT No Voice Prompts Reply with quote
rhd4609 wrote:
Embarassed
.........and the beep is almost unhearable can I adjust
Robert
The beep is on the same volume as the guidance-voice so if you increase the navigation-volume the beep gets louder as well.
