Pocket GPS World :: View topic - WARNING DO NOT INSTALL NEW NAVCORE9 ON GO940
MrT
PostPosted: Tue Jul 20, 2010 12:12 pm    Post subject: WARNING DO NOT INSTALL NEW NAVCORE9 ON GO940 Reply with quote
As per the other thread this update offered by Home stops the SIM from working.
Drivelux
PostPosted: Tue Jul 20, 2010 2:39 pm    Post subject: Reply with quote
... unless of course you have a good backup you can revert to! Smile
I can confirm you can roll back to v8 successfully.
Guivre46
PostPosted: Tue Jul 20, 2010 3:09 pm    Post subject: Reply with quote
Why do they keep releasing these technological inadequacies? At the very least you'd think they could get their own staff to try prototype software in the real world before unleashing it Rolling Eyes
Mike R [aka Wyvern46]
Go 530T - unsupported
Go550 Live [not renewed]
Kia In-dash Tomtom
Matt865
PostPosted: Tue Jul 20, 2010 6:57 pm    Post subject: Reply with quote
I'd pretend to be shocked but I'm way past the point of expecting competence from TomTom. Doesn't work on a 740 either. The SIM error is exactly the same as you get when you try to run a x50 navcore on a x40 device. I guess they're using their customers as beta testers to see if that navcore works without them putting in any effort to make it compatible with older devices.
AndyVaughan
PostPosted: Tue Jul 20, 2010 7:44 pm    Post subject: Reply with quote
I haven't seen any mention of resets being performed by anyone - only reloading the application?
The only reason I mention this is that when Nav9 was released for the XL LIVE all my LIVE services stopped with loads of random errors.
Worth trying the following
Perform a reset to factory settings
Perform a power button reset - keep it held in until after the drum roll and the screen appears with the small text on it. Now briefly press the power button and the GO will power back on.
Perform another reset to factory settings
For good measure run clear flash a few times (3 is recommended)
Now another factory reset
Now set up with home location, username and password for LIVE etc. Make sure you do a navigate to... as this will prompt you to choose the country for the maps. Now get a satellite fix - Nav9 doesn't seem to like kickstarting the LIVE services into action until it has had a satellite fix.
Worth a try???
MrT
PostPosted: Tue Jul 20, 2010 8:22 pm    Post subject: Reply with quote
Tried it all. It won't even let you get as far as trying to put your username and password in. The network screen shows and all the usual four lines of information comes up except it will not show connected, although from the interference it makes on my computer speakers, it sounds like it is talking.
I have used 950 navcores on the 940 before and did not have this issue, but did suffer from the battery flattening when off and if an error occured on live services it gave up rather than retrying.
Drivelux
AndyVaughan
PostPosted: Tue Jul 20, 2010 8:34 pm    Post subject: Reply with quote
Looks like it is a dodgy release then.
Why don't you install the 9.054 from the XL LIVE over the top manually and see what happens???
Available here
Bootlader in this is 5.5138 so won't upgrade 5.5260
stephenbeharrell
PostPosted: Tue Jul 20, 2010 8:37 pm    Post subject: Yep me too Reply with quote
Just to confirm what others have found, the only solution is to revert to your backup. No amount of resets work - I thought TTs were supposed to save time!!!
I wait with interest on TTs customer service reply.
Covenant
PostPosted: Tue Jul 20, 2010 11:44 pm    Post subject: Reply with quote
Hey guys - just to confirm, I tried this update on my Go 540, and exactly the same thing happend (Sim card 1008 error).
Thought I'd add my tuppence Smile
RATOM
PostPosted: Wed Jul 21, 2010 4:04 am    Post subject: Navcore 9 Reply with quote
Installed this new navcore and 740 is throwing 1008 error, when it comes to live services. Contacted Tomtom and after they made me try all possible solutions, the case has now been referred one level up.
Removed the new application from interal memory and reinstalled the back up with navcore 8 something but live services still will not work and give error 1008. Am I doing something wrong? please.
ratom
RATOM
PostPosted: Wed Jul 21, 2010 4:05 am    Post subject: Navcore 9 and error 1008 Reply with quote
ratom
radville
PostPosted: Wed Jul 21, 2010 8:23 am    Post subject: Reply with quote
What now? I'm so fed up with technology, it's one thing after another! I didn't see there was a problem before I downloaded. Please tell me what I should do. Will the error be fixed to run with this lovely new upgrade and should I leave it or should I revert to a backup? Now I'm not sure if I have ever backed up if I have I won't be able to do it till I go home to my pc and then how do I do it? My wife's going to go mad all I do is try and fix things that I was prompted to do in the first place, PLEASE HELP
D
Anita
PostPosted: Wed Jul 21, 2010 11:24 am    Post subject: Reply with quote
radville wrote:
Now I'm not sure if I have ever backed up if I have I won't be able to do it till I go home to my pc and then how do I do it?D
Instructions for backing up can be found in the TomTom FAQs sticky at the beginning of the TomTom PNDs forum. It is advisable always to back up using this method before installing new software or maps.
It's also wise to check the forum before downloading "upgrades" from TomTom. Some of our users will post their findings, and warnings, pretty soon after the release, so you can make an informed decision whether to go ahead.
Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21
23.061 (04 Jun 25)
