Pocket GPS World :: View topic - Problem with BC-307 & tomtom 3.03 GPS drivers
I_Need_Help
PostPosted: Sun Jul 25, 2004 4:41 pm    Post subject: Problem with BC-307 & tomtom 3.03 GPS drivers Reply with quote
I have a Dell X5 and the above which has worked well for some time but over the last three or four days it struggles to get a “lock” and when it does it is normally only tracking with 3 satellites when it uses to track with 5 or more! It still does on occasions get 5 or 6 but generally it is lower then before!
I have always used NMEA 0183v2 via CF (is this the correct one it worked so I have never questioned it!)
OK here is the likely problem about a day or two before the problem started the casing broke between the CF card and the pod however it appears that the connection between the two is on a short wire loom so I glued it back and it seem to work OK and as I can still get some Satellites OK (two or three) so I assume that this was not the problem!
Using the external aerial makes no difference to the reception.
How can I check if it working OK is there away of adjusting the sensitivity? Can this be done with some of the tweaking tools?
Sometimes I notice that I have a few sats but only 3 are red why is this?
And as an aside in the Tomtom gps setting there are two sliders one is to do with sound what is the other one for?
Sad
lbendlin
PostPosted: Sun Jul 25, 2004 6:37 pm    Post subject: Reply with quote
We're talking High frequency magic here. Any tampering with the circuitry will result in data loss... even the glue may have an impact (do you know if it is conducting?)
Some of the sats show as grey because the SNR (Signal-to-Noise Ratio) is not good enough to be considered reliable (must be above 30 dB).
The left slider is for the power save override. In the "on" position TomTom will prevent the Pocket PC from going into Standby mode.
Lutz
TomTom/TeleAtlas NAVTEQ
I_Need_Help
PostPosted: Sun Jul 25, 2004 7:05 pm    Post subject: Reply with quote
Thanks for the info and help.
It was super glue applied to the black plastic casing I have opened it a check it did not get on to the receiver and the point of gluing was on the side of the CF card just at the point where it pokes out of the PPC.
the grey bars are about 75% is this an indication of signal strength how high is 30 db?
Currently as I type I have 3 red sats 9, 5 & 30 (are these the strongest in the UK? (I'm up near the Wash). actually they have just all gone grey without it being moved and the lines are approx. the same level as when they were red! the only other difference is 5 has been replaced with 14!!!
thanks
lbendlin
PostPosted: Sun Jul 25, 2004 8:10 pm    Post subject: Reply with quote
The sats are not geostationary. They circle the earth in about 12000 km distance. So it is very normal that they appear and disappear.
I'd think the bar must reach 80% to be coutned as red=good.
Lutz
I_Need_Help
PostPosted: Mon Jul 26, 2004 11:42 am    Post subject: Reply with quote
Its working again! I don't quite know why but I followed http://www.pocketgpsworld.com/winfastnavigatorppc.php
Loaded the app and done:
run up WinFast Navigator, connect to the GPS Receiver, then go into the COMMAND option and for this test we will make sure GSV is set at 5, then tap OK
And now its back to normal!!!! :D
In the same place I now have not 3 red bars but 5 and 1 grey.
22.071 (03 Jul 24)
