Pocket GPS World :: View topic - Help needed with sounds to speech for Kenwood DNX5220bt
Goto page 1, 2, 3  Next
gav311
PostPosted: Mon Jun 28, 2010 11:34 am    Post subject: Help needed with sounds to speech for Kenwood DNX5220bt Reply with quote
I have a kenwood dnx5220bt i have installed the speed camera database. I have also attempted to change the warnings sounds to the speech as per the instructions on the site, but my device keeps playing the cd and not updating into the hard drive. can anyone help with this issue please.
Regards, Gavin
PaulB2005
PostPosted: Mon Jun 28, 2010 12:15 pm    Post subject: Reply with quote
Hi and welcome.
You mean it plays the alerts track by track?
You have to put the mp3 files into the same folder as your speed camera files on your PC. Then use POILoader, which will combine them all (CSV, BMP and MP3) into one big file, called POI.GPI (as you have done already). You then load this to your unit.
Ignore it if POILoader reports it's stopped responding or appears to freeze. Give it time....
See the instructions on the download page here
gav311
PostPosted: Mon Jun 28, 2010 2:22 pm    Post subject: kenwood dnx5220bt Reply with quote
Hi, Thank you for you response. I have uploaded in the way the describe, but didn't call the file poi. just called the folder garmin. would that make the difference?
Also if possible could you advise me how to change the background to a photo of my choice.
Kind Regards, Gavin
PaulB2005
PostPosted: Mon Jun 28, 2010 2:52 pm    Post subject: Reply with quote
Hmmm. It should make a folder called Garmin and a file in it called POI.GPI.
Did you have the camera database and the icons in the upload folder too? (i.e. not just the mp3s)
gav311
PostPosted: Mon Jun 28, 2010 3:49 pm    Post subject: kenwood dnx 5220bt Reply with quote
Hi, Ive download the lasted speed camera zoned files together with the speech file unziped both into my garmin empty folder that i created on my desktop put the folder into poi loader to convert then burned on cd.
is that the correct way of doing this?
regards, Gavin
PaulB2005
PostPosted: Mon Jun 28, 2010 4:10 pm    Post subject: Reply with quote
Do you have matching triplicate files?
i.e. (NOTE Your actual files names might be different but you should get the point....)
GATSO_30.CSV
GATSO_30.MP3
GATSO_40.CSV
GATSO_40.MP3
etc
If so, POILoader should spit out a large file called POI.GPI. If it has then that should be all you need to do..
gav311
PostPosted: Mon Jun 28, 2010 4:17 pm    Post subject: Reply with quote
Hi, shows all files with icons and file names. poi doesnt give a file back just states that poi have been added. then i burn that file.
PaulB2005
PostPosted: Mon Jun 28, 2010 4:38 pm    Post subject: Reply with quote
So what is the file called? POI.GPI?
gav311
PostPosted: Mon Jun 28, 2010 4:40 pm    Post subject: Reply with quote
the file is the one i created on my desktop called garmin
PaulB2005
PostPosted: Mon Jun 28, 2010 4:45 pm    Post subject: Reply with quote
Sorry to really labour this point, but POILoader usually generates a file (not a folder) called POI.GPI
This is the file you should be looking for. Not the folder.
It should have been generated by POILoader and not you....
cjay2412
PostPosted: Mon Jun 28, 2010 5:00 pm    Post subject: Reply with quote
GATSO_30.CSV
GATSO_30.MP3
GATSO_40.CSV
GATSO_40.MP3
etc
correct me if im wrong but dont the voice files have to be converted to wav format for them to work
gav311
PostPosted: Mon Jun 28, 2010 5:38 pm    Post subject: Reply with quote
im not sure but i dont think so.
gav311
PostPosted: Mon Jun 28, 2010 5:57 pm    Post subject: Reply with quote
Hi found the poi file, i wasnt using the loader correctly. what now? i tryed burning straight to disk didnt work?
PaulB2005
PostPosted: Tue Jun 29, 2010 7:10 am    Post subject: Reply with quote
Only if your unit doesn't have an MP3 player.
What did happen? Messages etc You just need to do the same as you did before.
PaulB2005
PostPosted: Tue Jun 29, 2010 7:27 am    Post subject: Reply with quote
Further to the above you need to have the POI.GPI file in the following folder format
x:\garmin\poi\poi.gpi
You must also finalise the CD and make sure you can see the files on the CD with your PC. Use good branded CDRs not CDRW.
Then turn the unit on select [NAV} and insert the CD.
Some also mention that if you get any messages about Disc Error to ignore them and wait a bit..
Page 1 of 3
