ROBBINS Regular Visitor
Joined: Dec 04, 2003 Posts: 82 Location: Worcestershire
Posted: Thu May 20, 2004 10:14 pm Post subject: |
Why do HP send a replacement battery door. Can this sometimes be faulty also? I have ordered replacement aluminium sides from Expansys, but they have been on back order for about two weeks to date.
Thanks |
tom9851 Frequent Visitor
Joined: Feb 14, 2004 Posts: 283 Location: Warrington, Cheshire.
Posted: Fri May 21, 2004 6:51 am Post subject: |
The replacement battery door HP have sent me is identical to the one already fitted to my 2210. I think the replacement door is different in as much as it has a small rubber pad on it which presses against the battery thereby making for a better connection I guess. I can only assume that earlier 2210's had a battery door without this pad, I don't know for certain because I've only had my current 2210 since Feb.
Tom |
icsys Frequent Visitor
![](http://www.getoutguide.pwp.blueyonder.co.uk/screenshot/Animation3.gif)
Joined: Feb 20, 2004 Posts: 1154 Location: South Lancashire, UK
Posted: Fri Jun 11, 2004 12:27 pm Post subject: |
Hmmm After four months of careful use, my grips have started to peel away. They appear to have swelled and now bulge out at the bottom and refuse to stay in place.
Hopefully I will get the replacements soon too :| . _________________ Ian.
iPAQ 2210 | Navman 4100 BT Receiver
Navman iCN 635
TomTom GO
Anquet OS mapping
Posted: Fri Jun 11, 2004 12:40 pm Post subject: |
Well if you have called that same number I did then you won't have to wait more than a few days - even though they will come from Holland via UPS!
My replacement ones are still looking ok, but the constant use of my 2210 in the TomTom car kit holder is putting a lot of pressure (very tight fit!) on the 2210's side grips. However I will just ask for a replacement set when they start to bulge again! At the end of the warranty period I will probably buy the aluminium ones as mentioned in a previous post.
Hope you get yours soon.
Tom _________________ ___________
IPAQ2210/ROM-1.10/LEXAR 32X 256MB SD/Kingston ElitePro 1GB CF
TTN3-V3.03/Wired GPS-V3.03/Globalsat BT-338 |
dunno Regular Visitor
Posted: Tue Jun 15, 2004 5:41 pm Post subject: |
thanks darren i have just given them a bell now should be in the post , not interested in the other stuff just want my grips :D
ps love this site got 2 problems solved today postcodes and now this |
Mearns Lifetime Member
Joined: 24/08/2003 18:17:58 Posts: 162 Location: Aberdeen, Scotland
Posted: Fri Jul 23, 2004 10:36 am Post subject: New HP Support Number for this problem |
Just an update on the UK HP support telephone number to ring to get new 2210 side grips. Mine fell apart today with 9 days to go until the warranty expired!!
New number: 0845-270-4015 then use menu options 1 then 3 then 4 and if you're lucky you'll get through to Linda who has the most attractive Irish lilt to her voice - quite made my day! _________________ Tony
nuvi 2460LT plus Brodit mount |
ttrevor Lifetime Member
![](modules/Forums/images/avatars/gallery/1_block2_satellite.jpg)
Joined: Dec 04, 2003 Posts: 540 Location: Sleaford Lincolnshire UK
Posted: Fri Jul 23, 2004 5:26 pm Post subject: |
just received my side grips from HP ,first class service,plus a spare battery cover and cf slot cover, ![Thumbs Up](modules/Forums/images/smiles/custom2.gif) _________________ Iphone x 64gb IOS 11.3.1 / IPhone 6 Plus 32gb IOS 12 beta /Volkswagen Scirocco R 280 bhp /Suzuki Vitara swb vvt+ /Suzuki Jimny special/running Apple Mac Mini / Apple air/ iPhone x /6 plus navigation / Apple car-play |
ukpete Occasional Visitor
Posted: Fri Jul 23, 2004 6:02 pm Post subject: |
You can also request them online from the HP active chat service
http://instantsupport.europe.hp.com/euserv/jsp/hpinstantsupport.jsp
Was very impressed to get the battery cover, CF cover and side grips UPS expressed. The packaging/shipping alone must of cost HP more than the side grips cost to manufacture. Top marks to HP though ![Thumbs Up](modules/Forums/images/smiles/custom2.gif) |
Ains Occasional Visitor
Posted: Sat Jul 24, 2004 7:24 am Post subject: Side grips / 2210 tight fit |
Has anyone find a way of easing the tight fit of the 2210 into the TT holder ?
TT offered to send a replacement holder, but only if I send back the original first (i.e. no TT for a week or so) Fair enough, I suppose, but a pain.
Do the HP replacement grips ease the fit ? I can't get the IPAG out of the holder without using two hands and occassionally pull the holder off the screen as the fit is so tight
Ainsley |
Posted: Sat Jul 24, 2004 3:25 pm Post subject: |
Ains,
You are not alone with this problem. The side grips on my 2210 had to be replaced after only a few months - due mainly I believe to the very tight squeeze to get the 2210 into the TT holder. With replacement grips fitted I think it won't be long before these too are knackered by the difficulty in getting the 2210 out of the holder! From my personal experience the replacement side grips are identical to the original ones. Think the only solution to this problem (I too have to use both hands to remove it from the holder) is to keep getting the grips replaced by HP under the warranty and then buy a set of aluminium grips that will never deteriorate. I don't know if these aluminium ones are easier to get out of the holder - am sure someone who has these fitted can answer that though.
cheers
oddsock Pocket GPS Verifier
Joined: May 01, 2004 Posts: 706 Location: Monmouthshire
Posted: Sat Jul 24, 2004 5:09 pm Post subject: |
My 2210 grips have gone :x or should I say the left grip has,and its only a month old Its nothing to do with it being tight in the TT car cradle (although it is tight) but the fact that the oils in the skin may have softened it (my theory cos the Sky remote has done the same thing but thats taken 4 years ) I have the ipaq in a Krusell Handit case and right at the top left corner where I crook my thumb around it when I hold it in my hand the rubber has expanded and bulged out. Going back to the TT car cradle, I can see where it is too tight on the PPc by the 15mm long witness mark it leaves on the side grips (These start 10mm from the bottom)Has any one else noticed these
Dave |
marshall Regular Visitor
Joined: 01/09/2003 10:29:35 Posts: 113 Location: Lancashire
Posted: Sat Jul 24, 2004 6:28 pm Post subject: |
hi to everyone
I have had a replacement set of side rubbers, but now these are bulging starting about 10 mm from the bottom.
I seems the TT car kit is to tight a fit and I would have thought the replacement rubbers would have taken this into account.
Its not good enough to issue a new set of side bits and hope they last longer than the guarantee.
I think its very poor that they replace until the guarantee runs out and then we are on our own.
What sort of customer care and product design is this?.
Still I suppose you pays your money and -----!!!!!!
Keep the forums going, they are a real gold mine of knowledge.
Regards
Marshall |
mgibbs Occasional Visitor
Joined: Jun 07, 2004 Posts: 48 Location: North Lincolnshire, UK
Posted: Sun Jul 25, 2004 9:32 am Post subject: |
Sorry but you can't blame HP for providing replacement rubber grips that are too big for the TomTom car cradle.
Its TomTom who should have made the car cradle slightly wider. After all, its supposed to fit the iPaq not the other way round.
Mark |
