Pocket GPS World :: View topic - Tom Tom RDS-TMC Traffic Receiver (4V00.013-Jack End)
DraySoft
PostPosted: Sat Jun 19, 2010 3:58 pm    Post subject: Tom Tom RDS-TMC Traffic Receiver (4V00.013-Jack End) Reply with quote
Hi All,
Has anyone a photo of the inside of the above receiver showing the position of the four coloured wires (red,orange,green and black).
Best regards,
Draysoft.
PostPosted: Sun Jun 20, 2010 12:27 pm    Post subject: Reply with quote
I've got one of those somewhere.
If I can dig it out, can you remind me how easy it is to get the case apart?
DraySoft
PostPosted: Sun Jun 20, 2010 3:02 pm    Post subject: Reply with quote
Hi Andy,
Thanks for the reply, I just gentley squashed the 'egg' in a small vice and it split open.
Draysoft.
spook45
PostPosted: Sun Jun 20, 2010 10:37 pm    Post subject: Reply with quote
DraySoft wrote:
Hi Andy,
Draysoft.
That is certainly one way. For a cleaner extraction I recommend a Dremel tool around the edges.
PostPosted: Mon Jun 21, 2010 12:18 am    Post subject: Reply with quote
Hmmm... not too sure I want to have to saw it apart.
I'll have a look and see....
JoolsTwo
PostPosted: Mon Jun 21, 2010 11:58 am    Post subject: Reply with quote
is this it? found it on another posting
TomTom ONE Series 30 (v8) & TMC traffic
App 8.010, UK & ROI Map v860.3126, TT Home 2.7.6.2056
DraySoft
PostPosted: Mon Jun 21, 2010 7:55 pm    Post subject: Reply with quote
Hi JoolsTwo,
Many thanks that is just what I needed :-)
Draysoft
DraySoft
PostPosted: Mon Jun 21, 2010 9:33 pm    Post subject: Reply with quote
I now again have a working TomTom RDS-TMC Traffic Receiver type 4V00.013 with my 720.
It all started to go wrong when the windscreen of my works van was replaced, the fitter fractured the lead between the ‘egg’ and the jack plug I now know in two places one right against the ‘egg’ and the other at the jack end.
In my hast to repair it I mislaid my sketch of the position of the four wires even when I did have the correct combination it did not work, because of the second fracture.
It is now hard wired to my Carcomm Cradle and is working as well as it ever did.
One final question what is the latest traffic receiver that will work with the 720 and what firmware version is required?
By the way using the vice method allows the 'egg' to be glued together afterwards as it just springs apart.
AndyVaughan
PostPosted: Tue Jun 22, 2010 9:43 pm    Post subject: Reply with quote
I used one of the USB RDS-TMC receivers with a 920, but I found that the reception was better with the .013
The usb one gets annoying after a while as it powers from the power adapter, so if you turn the ignition off you lose TMC if your cig lighter socket is switched with the ignition and not permanently live. So, stopping at a petrol station meant all traffic info was lost and you had to wait 5 mins or so for it to lock on again after resuming your journey.
If the .013 one is working for you then stick with it.
