vanduara37 Occasional Visitor
Posted: Sat May 29, 2010 8:30 pm Post subject: operate my device |
On TT home when i try to" operate my device" i get the message "problem with map,this map cannot be used on this device"but the satnav works fine with the installed map.anyone shed any light on this ?
John |
Posted: Sat May 29, 2010 8:47 pm Post subject: |
This is becoming quite a regular one recently, there is an issue with TomTom Home or the servers at TomTom that is at fault. There is little you can do other than complain to TomTom using the following phone number 0845 161 0009.
If enough people complain about the issue they might do something about their crap software you have to put on your computer to interface with the device, personally I try not to use it at all where possible - Mike |
Posted: Sat May 29, 2010 11:49 pm Post subject: |
So basically i,m f****d unless tt home sort out the issue ? |
Posted: Sun May 30, 2010 8:24 am Post subject: |
Contact TomTom on the number I gave earlier, unless people complain they won't do anything - Mike |
rockin_plumber Lifetime Member
Posted: Sun May 30, 2010 11:42 am Post subject: |
vanduara37 wrote: | So basically i,m f****d unless tt home sort out the issue ? |
Not really.........
I have never tried it so wouldn't know if it works on my TomTom
If its just operate my device on the PC that wont work........
Why not just operate the device...... by operating the device |
Calomax Lifetime Member
Posted: Sun May 30, 2010 11:47 am Post subject: |
rockin_plumber wrote: | vanduara37 wrote: | So basically i,m f****d unless tt home sort out the issue ? |
Not really.........
Why not just operate the device...... by operating the device | One small problem with that is, if you send a location to your device from Google Maps, it needs to open the emulator before you can save it. _________________ TT Go Essential |
Posted: Sun May 30, 2010 12:53 pm Post subject: |
Why not just operate the device...... by operating the device [/quote].
The reason i need it to wwork is i have a problem with satnav freezing when i select "postcode"and was advised of a solution by another member in an earlier post and the solution involved using "operate my device"on the pc. |
Posted: Sun May 30, 2010 9:37 pm Post subject: |
Well there you go then, now I know
Hope you have some luck with TomTom then |
