Pocket GPS World :: View topic - Routing on Sat Navs - how to do it
Stuff24
PostPosted: Fri May 21, 2010 11:45 am    Post subject: Routing on Sat Navs - how to do it Reply with quote
I've put together a three part tutorial on YouTube which describes how to do this, as I know it is a confusing topic for many.
Routing explained, particularly for Garmin Nuvi 700/800 series, using free software and services
What is routing? GPX Files, TomTom ITN files
Preparing routes on the device and using software
Part 1 http://www.youtube.com/watch?v=laay3AOjFr4
Part 2 http://www.youtube.com/watch?v=hL3qh2tdSaE
Part 3 http://www.youtube.com/watch?v=JV0kg4CaaZk
Check them out.
cwog
PostPosted: Fri May 21, 2010 1:33 pm    Post subject: Reply with quote
Thank you for creating the videos.
What I did not follow was how you created the GPX file from the route on the Google Map. Could you please expand (in a reply - not a video update) what one does to create the GPX file
cwog
PostPosted: Sat May 22, 2010 12:50 pm    Post subject: Reply with quote
Thanks to your video I have discovered a few things.
I used GMaptoGPX to create the GPX file from the Googlemap route.
I had to then save it to the hard drive with no line feeds and with a GPX name.
I could then open the GPX file in BaseCamp and display the route on the maps in Basecamp - so checking that the route is readable, I then copied and loaded it into the SatNav a nuvi 775. Where it then worked.
As an aside using Basecamp (a Garmin supplied program) may in some circumstances be a better option - you do not get the variable routing option that you get in Googlemaps but you get a one step update to the Satnav using Mapinstall which is called by Basecamp - ensure that you deselect the install Maps etc.
Again thanks for your prompting to get to know more about the intricacies of the nuvi
Stuff24
PostPosted: Sat May 22, 2010 11:20 pm    Post subject: Reply with quote
I used the TYRE program which I talk about in the video. I designed the route in Google Maps, and then TYRE has the facility to import the route from the Link URL you can obtain from Google Maps. This is explained in the video. It might not be clear, because I did try to use a screen capturing program to make the video, as well as the video camera, but the screen capture failed.
cwog
PostPosted: Sun May 23, 2010 10:13 am    Post subject: Reply with quote
Thanks - I didnot connect that tyre did the direct conversion - however tyre is a 'doze only program - my workaround works on all operating systems (I think) as the conversion is done via the URL of the GMapToGPX site
Stuff24
PostPosted: Tue May 25, 2010 8:53 pm    Post subject: Reply with quote
have done a quick 5 min vid showing the process in more detail
http://www.youtube.com/watch?v=FOBjKxrmbf8
