Pocket GPS World :: View topic - Planning walking routes
BarrieB
PostPosted: Fri May 21, 2010 7:45 pm    Post subject: Planning walking routes Reply with quote
Can anyone tell me which, if any, of the current TOMTOM models are capable of planning walking routes from A to B (around the streets of a city, not in the countryside)
Thanks,
PostPosted: Fri May 21, 2010 9:12 pm    Post subject: Reply with quote
Any device without the simplified menu system employed on devices such as the newer XL-2 units and the Start. If you avoid these models you get the pedestrian option for route planning - Mike
PostPosted: Sat May 22, 2010 2:24 am    Post subject: Reply with quote
Have to say, the few times I've tried it, I've never found walking with a TomTom in towns terribly successful. It kind of works, but only just.
It seems you don't move fast enough for the TT to consistently know which direction it's going in and the "urban canyon" problem of blocked or reflected GPS signals seems worse somehow.
Also, the mapping is still only for roads, so it won't take you down any footpaths or alleyways as short cuts. The only real difference is that it will let you go down one-way streets the wrong way.
BarrieB
PostPosted: Sat May 22, 2010 9:05 am    Post subject: Planning walking routes Reply with quote
Thanks for this.
The other question I supose is battery life. Are any of the TOMTOM's good for 6 or 7 hours wandering round London?
Can they be 'topped up' from a usb battery pack?
PostPosted: Sat May 22, 2010 9:33 am    Post subject: Re: Planning walking routes Reply with quote
A good battery fully charged will give little more than 2 to 2,5 hours in use, don't believe all the stupid figures claiming 5 hours battery life which have been seen on adverts/ web pages from TomTom.
Yes you can use a USB power pack, the U2O 5400mA pack like This Item for additional power for a number of my devices - Mike
metradio
PostPosted: Sat May 22, 2010 4:56 pm    Post subject: Re: Planning walking routes Reply with quote
mikealder wrote:
...Yes you can use a USB power pack, the U2O 5400mA pack like This Item for additional power for a number of my devices - Mike
I use one of these off of eBay:
Auction # 110522455662
4 BATTERY USB CHARGER/POWER PACK AAA RECHARGEABLE NIMH
Works fine and at £3 it is £45 cheaper Exclamation
BarrieB
PostPosted: Sat May 22, 2010 9:18 pm    Post subject: Planning walking routes Reply with quote
Thanks for your help
Calomax
PostPosted: Sun May 23, 2010 5:51 pm    Post subject: Reply with quote
It's also worth looking at the PowerMonkeys which are multipurpose and have a solar charger as well http://www.powertraveler.com/
TT Go Essential
Seamaster
PostPosted: Sun May 23, 2010 6:35 pm    Post subject: Reply with quote
Andy_P wrote:
Have to say, the few times I've tried it, I've never found walking with a TomTom in towns terribly successful. It kind of works, but only just. It seems you don't move fast enough for the TT to consistently know which direction it's going in...
The same problem bedevils the iPhone Tomtom app, which is particularly disappointing for me as it was the principal reason I bought it. I have a 740 for my car, I wanted the iPhone app to navigate unfamiliar cities on foot.
I don't think there's any hardware-based technical reason for it. I note, for example, the Google Maps app on the same hardware and in the same terrain seems much better at tracking location/direction on foot.
I've raised the issue with Tomtom a couple of times, but they've as much as said they're not interested in fixing it. Why they continue to include, and advertise, pedestrian routing that simply doesn't work is baffling.
PostPosted: Sun May 23, 2010 7:51 pm    Post subject: Reply with quote
It would be useful if pedestrian mode switched the Sirf Star lll chipset Static Nav on and off so as to enable GPS tracking at less than 3MPH. iGO does not do this either, but I think that the chipset needs a reset to enable/disable Static Mode (but I'm not sure of this).
PostPosted: Sun May 23, 2010 8:01 pm    Post subject: Reply with quote
Walking with a TomTom below about 5MPH is not much use as the display will wander all over the place, anything above 4MPH is really known as running.
If you want a true walking GPS system go for a dedicated device geared to slow speed, even a PDA loaded with Memory Map and paired to a SiRF-III GPS device will offer far better performance with Static Navigation set to off for walking and ON for car use (4MPH threshold) - Mike
BarrieB
PostPosted: Wed Jun 02, 2010 3:00 pm    Post subject: Reply with quote
Does the "Statnav" hack mentioned elsewhere on this forum work with a TomTom XL IQ Routes?
Thanks in advance?
22.055 (29 May 24)
