Pocket GPS World :: View topic - Can't get my free map updates onto NUVI 1310
CJ57
PostPosted: Sat May 08, 2010 12:55 pm    Post subject: Can't get my free map updates onto NUVI 1310 Reply with quote
As far as I can tell I've followed all Garmins instructions but with no luck. The update extracts, I click next and it says my device had not been updated, and I should switch it off then on and try agin. I've tried, and tried, plus downloaded the map update again in case the first was corrupted - thta'll be most of my download limit gone for the month! Anyone have any ideas what I might have missed? I'll try Garmin eventually but thought others may had experienced the same.
CJ57
PostPosted: Mon May 10, 2010 12:23 pm    Post subject: Reply with quote
Guess no one has had the same problem, but now successfully installed. The only thing I did differently this time was to update the software from version 3.4 to 4.00 before I did the install. Given the problems with some of the i3 firmware updates I was a little dubious about updating but everything seems OK - will try out on a run later this week.
Meter_Man
PostPosted: Thu May 13, 2010 7:39 am    Post subject: Failed update Reply with quote
I had this problem once, ended up downloading the map 5 times, then it worked! No idea why, can only assume it was data corruption on the download
CJ57
PostPosted: Tue May 18, 2010 7:44 pm    Post subject: Reply with quote
After both updates the Nuvi gave me a slightly different route for one of my journeys but nothing untoward as regards freezes and getting a satellite fix. I'm guessing that's the firmware update rather than the maps. If I can find it I may try reverting to 3.40 - anyone know where it may be hidden on the Garmin site?
dales
PostPosted: Wed May 19, 2010 11:48 am    Post subject: Reply with quote
You should find your software here - the Perry site.
Dales
22.063 (19 Jun 24)
