chrispartrick Occasional Visitor
Posted: Mon May 17, 2010 9:51 pm Post subject: Loading Europe cameras on TT720 |
My son has dropped me in it at short notice..Has TT720 with pocket_gps_uk_....cameras loaded on..informs me wants Europe cameras loaded on for weekend.What is easiest way..make copy of SD card & download pocket_euro_...cameras on & install on the ferry? Concerned re posts about mph/kph conflicts.Also where can I find the ogg files for euro cameras.Any other problems likely?Very grateful for any response. |
AliOnHols Pocket GPS Verifier
Posted: Mon May 17, 2010 10:00 pm Post subject: |
It is a straight forward download. just as you / your son already does for the uk download. Download the EUR files, extract and install in the folder which contains the map on your 720. You shall need to set the proximity alerts. Follow the links on the download page for custom sound files or assign your own sounds or type your own tts alerts (which I do as sound levels are compatable). There is no need to alter or delete any files you already have installed for the UK. _________________ Garmin Nuvi 2599
SatMap Active 10 & 20. |
Posted: Mon May 17, 2010 11:09 pm Post subject: Follow the links on the download page for custom sound file |
Thanks for your help Ali that does sound straight forward.
You mention the custom sound file links on the download page but I must be looking in the wrong place ...I can only see uk speed settings not euro, do you have a link please.Apologies. |
Posted: Tue May 18, 2010 9:35 pm Post subject: |
Thanks for the link Ali,I did'nt check that one.
Downloaded and copied/pasted (using "Select All"option) the europe bmp/ov2/ogg over to the Map folder but only about 9 categories appeared on the 720 when I tried to set up the proximity alerts.
On rechecking I found that quite a few different bmp & ov2 files had not been copied over. After identifying the missing culprits I repeated the process but with fewer files at a time, which appears to have been successful.Did I read somewhere that it is recommended not to copy more than 20 cats. at a time ?
Thanks again. |
