Pocket GPS World :: View topic - Upgrade advice for 920 with no internal memory
kissinuk
PostPosted: Sun May 16, 2010 1:48 pm    Post subject: Upgrade advice for 920 with no internal memory Reply with quote
My 920 is currently running v7 software and I would like to upgrade it to the latest version + maps. However, the internal memory on it stopped working some time ago and I've been running the software & maps direct from an sd card (very slow to start up but it does work at least). What is the best way to update this to the latest version? Would TT Home still work seeing as the internal memory has gone, or is there another way to copy the latest software direct to an SD card?
Many thanks,
Paul.
Anita
PostPosted: Sun May 16, 2010 2:08 pm    Post subject: Reply with quote
When I connect an SD card containing the TT software and map using a card reader Home sees it as a TT device and updates accordingly. Presumably it would also do so if you connect your 920 with non-working internal memory, but I haven't tried that, so can only recommend using a card reader.
Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21
PostPosted: Sun May 16, 2010 3:03 pm    Post subject: Reply with quote
Which version 7 Navcore have you got on the device/ card, start the unit and tap the sat strength meter followed by the version box the next screen will tell you whats installed.
Once we know what that is we can offer you some links to the newer Navcore versions negating the need to use Home for Navcore updates, it is important to load certain versions when updating a unit such as 7,481 which is why I need to know whats on the unit at the moment.
To install the Navcore without using Home you will need to download and install WinRar to your PC which you can download from Here using WinRar to install/ update the Navcore to an SD card can be done with the card in the device or in a card reader, I prefer the use of a card reader as its generally faster - Mike
kissinuk
PostPosted: Sun May 16, 2010 4:57 pm    Post subject: Reply with quote
Sorry, I did mean to put the full version - it's 7.221. Thanks for the help.
PostPosted: Sun May 16, 2010 7:43 pm    Post subject: Reply with quote
kissinuk wrote:
Would TT Home still work seeing as the internal memory has gone?
It actually seems to depend just HOW badly knackered your internal memory is!
Mine died quite slowly on my 720. For a while I could still use it but new things I tried to save to it wouldn't "stick". During that time Home still recognised the TT and let me access the SD card.
However, eventually the internal memory died completely and after that Home didn't recognise that the Go was connected at all, although Windows still saw the SD card as a separate drive as normal.
I worked it like that for some time, being able to use the TT itself as a card reader, but slowly, Windows started acting strangely when I connected the 720, so now I just use a card reader as Anita suggests.
Anita wrote:
....so can only recommend using a card reader.
So long as you have the entire system and maps on the card, plug it into a reader and run Home.
Home should now act exactly as if you had connected the TT itself.
