Pocket GPS World :: View topic - opening up winzip
opening up winzip
bigles
PostPosted: Fri Apr 16, 2010 3:36 pm    Post subject: opening up winzip Reply with quote
I have downloaded new update onto my laptop but when download is complete and I press open I get the winzip box I press agree and unzip file but I do not get the box shown in example to extract all.I get all the various elements displayed in a document file.As someone who is pretty much computer illeterate I need explained in the simplest way.I have a tom tom 540 go.
PostPosted: Fri Apr 16, 2010 7:04 pm    Post subject: Re: opening up winzip Reply with quote
bigles wrote:
.... but I do not get the box shown in example to extract all.
I don't either. What I do is Double Click the Zip File, or Right Click and choose Open with ..., and Select WinZip. Either will open WinZip and display the files in the Zip.
Do you mean you see the Files in the WinZip Window? If so then you are already there.
Now go to Step 4 in the instructions, where you select the files to want to extract.
TT Via 135 App 12.075: Europe Map v1135
PaulB2005
PostPosted: Sat Apr 17, 2010 1:29 pm    Post subject: Reply with quote
In the instructions you are told to Save the file to a known location and then
right-click and select "Extract All"
However as you have WinZip installed this has taken over the built in ZIP file handling and complicates matters slightly.
You'll need to save the file to your hard drive and then right click the file and see if you get an Extract All option.
bigles
PostPosted: Sat Apr 17, 2010 6:16 pm    Post subject: Reply with quote
Have deleted everything and started again.downloaded again and saved to hard drive.When i go to open I get the same winzip box come up and i cannot progress further.I press the agree box etc.but i cannot get the extract all box to appear.I have also done a complete scan for any viruses that may have been interfering.Last saturday when i did my first download it all went as per the instructions.
richard345
PostPosted: Sat Apr 17, 2010 7:31 pm    Post subject: Reply with quote
This may be a red herring, but do you have a full version of WinZip installed, or an evaluation copy? This may be the cause of the Agreement that you are required to accept.
With the Full version, on double-clicking the zip file, I see a list of .ov2 and .bmp files and then I click the 'Extract' button at the top and make sure that there is a tick mark in the 'All Files' bit of the small pop up.
Hope this helps.
Ric - TomTom 520 DEAD - Passed to the great traffic jam in the sky. Now using Maps & Waze on Samsung Galaxy S4 + CamerAlert of course!
PostPosted: Sat Apr 17, 2010 9:52 pm    Post subject: Reply with quote
As Paul mentions above, you don't actually NEED Winzip at all if you are using a Windows PC. The PC can unzip files all by itself.
Unfortunately, it seems you have got a version of Winzip installed and it is trying to take over.
If you don't think you need it for anything specific, you could just uninstall it (Start menu, Settings, Control Panel, Add/remove programs)
Then, next time you try it, you should be back to the normal "Right click and Extract all" situation.
bigles
PostPosted: Wed Apr 21, 2010 9:51 am    Post subject: activating database Reply with quote
Thanks for your suggestions guys.When I try to open downloaded database from C drive the screen starts flashing at very fast speed and at the bottom of screen it is alternating between internet explorer and something else to fast to read and I have to shut down lap top from power button.has obvoiusly done something to lap top will have to take into I.T. and get fixed I guess
PaulB2005
PostPosted: Wed Apr 21, 2010 9:52 am    Post subject: Reply with quote
Did you try to click on the other thing that was too fast to read?
22.094 (25 Sep 24)
