Mark Occasional Visitor
Joined: 15/02/2003 18:53:37 Posts: 11 Location: United Kingdom
Posted: Sun Apr 11, 2010 5:11 pm Post subject: Speed Managment Device Advice requested |
I am trying to find a “Speed Management” GPS ie one that knows the speed limit in its current location and can warn of over speed. I don’t just want to know where the safety cameras are. Can anyone recommend a GPS system that can warn me that I am speeding and not just warn of camera location?
Thanks in anticipation.... Mark |
AliOnHols Pocket GPS Verifier
Posted: Sun Apr 11, 2010 7:00 pm Post subject: |
TomTom has this facility, Garmin too I believe, not sure about the others. My TT beeps at me when I go about 5kmh above the speed limit after a few seconds. Not all roads are listed and not all listings are accurate. I can correct the road speed errors manually if it bothers me that much. _________________ Garmin Nuvi 2599
SatMap Active 10 & 20.
Posted: Sun Apr 11, 2010 7:01 pm Post subject: |
Sorry but you won't find anything thats accurate compared to looking at the road signs displaying the speed limit as you drive down a road, from what I have seen from various devices/ software vendors with respect to the speed limit displayed its rather hit and miss - Mike |
BigPerk Frequent Visitor
Joined: Sep 06, 2006 Posts: 1618 Location: East Hertfordshire
Posted: Sun Apr 11, 2010 7:02 pm Post subject: |
Many satnavs can display both your actual speed and the recorded road speed limit (subject to data accuracy of course) - Navigon for one. But are you wanting an actual (eg audible) alarm? _________________ David
(Navigon 70 Live, Nuvi 360) |
M8TJT The Other Tired Old Man
Posted: Sun Apr 11, 2010 7:36 pm Post subject: |
iGO8 can be programmed to give overspeed alerts, both visual and audible, both as a MPH over the speed limit, or as a percentage of the limit. Having said that, it can only be as accurate as the map data, which is generally a bit on the suspect side and certainly should not be relied on, as mentioned by other posters above |
Posted: Mon Apr 12, 2010 12:24 pm Post subject: |
Many thanks for all the responses… What I’m trying to get to is an Audio alert when I am exceeding the speed limit of the location of the vehicle. I have TomTom on an HP Palmtop and I have used the camera POI system BUT…. I would prefer to be the good citizen and be within the limit at all other locations. I have a speedo but sometimes I miss the signs so no real help having another speed readout ……ideally a small electric shock might do the job but felt that a warning tone \ voice might be more readily available;-)
Is it the case that accurate speed zone maps are not yet available? |
GerryC Pocket GPS Moderator
Posted: Mon Apr 12, 2010 1:23 pm Post subject: |
Mark wrote: | Is it the case that accurate speed zone maps are not yet available? | Yes, that's basically the case. Many manufacturers offer this option but it's the data itself that is lacking. I would expect a lot of people who have this option would not recommend it as your primary speed limit warning - just stick to the signs.
Mark wrote: | ideally a small electric shock might do the job | Don't joke - someone may think you're serious.  _________________ Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount |
Posted: Mon Apr 12, 2010 1:26 pm Post subject: |
Hi Mark, All of the replies above refer to the road speeds tagged to the particular road you are on embedded into the map data from your SatNav provider and not to the camera POIs available from here. The road speeds embedded in my TomTom maps are reasonably accurate, but I do not risk my Driving Licence on them as some roads are wrong, some are plain silly and some are missing all together. I guess that the data embedded into maps from other suppliers maps shall be of equal (dubious) quality. I am not aware of any map provider with 100% coverage and 100% accuracy.
As I mentioned above, some TT's do offer the choice of either living with the speed errror/ommission or correcting it. _________________ Garmin Nuvi 2599
SatMap Active 10 & 20. |
Posted: Mon Apr 12, 2010 7:13 pm Post subject: |
I should have said the Navigons also provide an audible alert option for overspeed. I agree though that you should probably not rely on any satnav as your primary source - that's what the road signs are for ! The times that I do find it useful (with care) is when I have missed a speed-zone entry sign (usually where they are 'strategically' placed in a forest of other signs as you enter a roundabout and have other matters, like traffic avoidance, on your mind); or where I forget the limit on a long stretch which has repeater signs missing, especially where the limit changes frequently over a distance.
Also, I actually find the satnav's speedo display quite useful in extended road works. As has been pointed out elsewhere, this is a more accurate figure than the car's speedo, which reads deliberately low. Thus where the average speed specs say '50mph', nearly all the traffic is actually doing about 45-47, so where the stretch is some miles long and the outside lane is fairly clear, I actually make quite some progress by doing a genuinely legal 50 (but again with care ).
So the answer to your original question is that pretty well all makes will do what you say you want within the limits of their data accuracy. Let the Driver Beware! _________________ David
DennisN Tired Old Man
Posted: Mon Apr 12, 2010 8:50 pm Post subject: |
TomTom will do this if your particular model supports it (I have no idea of the feature set of TomTom on an HP Palmtop).
Try...
Change Preferences
Status Bar Preferences
Show Speed
Show Max Speed next to Speed
Then Change Preferences
Safety Preferences
Warn when driving faster than allowed.
Then, where the road speed limit is known by the TomTom map, it will show two speeds at the bottom of your screen. e.g. 50/70, where 50 is your current speed and 70 is the current speed limit according to the map. If you exceed the current speed limit by 3 or 4, it will beep at you and the speed display will change colour. The display colour will remain changed for as long as you exceed the limit, but it will NOT repeatedly beep at you. If it shows only one speed, it has no idea what the current speed limit is, so it won't warn you of anything.
All the above depends on your particular version of tomTom having this feature and very most of all the speed must be accurately known by the map. The accuracy (on mine) is very, very patchy. _________________ Dennis
Two of them are obesiting!! |
navver Regular Visitor
Joined: Dec 12, 2005 Posts: 111 Location: Chipping Sodbury
Posted: Sat Apr 17, 2010 4:45 pm Post subject: |
If its any help you dont need to see all the signs.
If there are street lights, it is 30mph unless there are small repeater signs at regular intervals.
If there are no street lights, it is national limits unless there are small repeater signs at regular intervals.
All quite simple however near me we have a section of road which is national limit but has street lights. The road from Bridgeyate to Siston in South Glos. _________________ Tomtom Go520, App 8.010, Map UK&ROI 810.1870 |
