Pocket GPS World :: View topic - Icons onto Igo8
Icons onto Igo8
chippy24
PostPosted: Sat Apr 03, 2010 11:08 pm    Post subject: Icons onto Igo8 Reply with quote
Hi Can you use bmp files as icons on IGO8 or do they have to be converted otherwise when you add new poi's all you get is google earth icon
thanks
PostPosted: Sun Apr 04, 2010 7:03 am    Post subject: Reply with quote
I believe that you can use uncompressed .bmp files in iGO8. Ther is a iGO bmp compressor/uncompressor which works on most types of iGO compressed .bmps, but other than for space reasons, try using them uncompressed and nsee if they wory Very Happy
chippy24
PostPosted: Wed Apr 07, 2010 4:45 pm    Post subject: Custom icons Reply with quote
Hi tried just putting the bmp icons on but no joy in them showing up in the poi icon section. guess there is something else you have to do, seem to think that linkjet posted the know how as to how it is done but cant find it. There has to be a way to put your own icons on for specific poi's and not just have the google earth all the time
linknet
PostPosted: Wed Apr 07, 2010 6:01 pm    Post subject: Re: Custom icons Reply with quote
It's here, 10th item down on the page:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=67086
linknet
chippy24
PostPosted: Thu Apr 08, 2010 4:49 pm    Post subject: icons Reply with quote
hi Linkjet thanks for your quick reply I dont wish to sound thick doh! but where exactly do you put the ui_igo8, I know you say put into the root folder, but where is this, I've had a look on sd card but dont seem to be able to find it?
thanks
Border_Collie
PostPosted: Thu Apr 08, 2010 10:26 pm    Post subject: Reply with quote
The ROOT of the SD Card is the Card itself before anything added, so just copy and paste the ui_igo8 folder straight on to the card i.e don't put it inside any other folder which is already there.
Once added you should see the 2577 Folder, the iGO8 folder, a backup folder and maybe a device .nng file and the ui_igo8 folder on the card.
linknet
PostPosted: Thu Apr 08, 2010 10:37 pm    Post subject: Re: icons Reply with quote
thanks
The root folder of any partition is the "highest" folder in the hierarchy. The root folder contains all other folders and can also contain files.
But what I actually said was "Unzip the ui_igo8 folder and copy it to the iGO8 root folder on the SD card giving 'iGO8\ui_igo8'."
Meaning the ROOT of the iGO8 folder not the ROOT of the SD Card so you finish up with 'iGO8\ui_igo8' Wink
linknet
PostPosted: Thu Apr 08, 2010 11:03 pm    Post subject: Reply with quote
What's in this ui_igo8 folder then??? I ain't got one Confused What am I missing out on Question
linknet
PostPosted: Thu Apr 08, 2010 11:19 pm    Post subject: Reply with quote
More icons. Smile
Yes you have, look inside your data.zip. Wink
linknet
PostPosted: Fri Apr 09, 2010 8:18 am    Post subject: Reply with quote
I knew that I had one there Very Happy but thought perhaps I was missing out on something not having one in \iGO8 Very Happy
linknet
PostPosted: Fri Apr 09, 2010 10:24 am    Post subject: Reply with quote
You can do that with any of the folders within the data.zip, iGO8 will use any files in the unzipped folders in preference to those in the data.zip.
linknet
PostPosted: Fri Apr 09, 2010 11:10 am    Post subject: Reply with quote
Ah, I see Shocked . I didn't realise that Confused
chippy24
PostPosted: Sat Apr 10, 2010 10:24 am    Post subject: icons igo8/ui_igo8 Reply with quote
Hi thanks for that Linknet think I've got it now, do I presume right that you then put your own Poi's and icons into this ui_igo8 folder instead of the one on igo?
linknet
PostPosted: Sat Apr 10, 2010 10:37 am    Post subject: Re: icons igo8/ui_igo8 Reply with quote
No, you need to read my original post, it gives full instructions on exactly what to do.
linknet
chippy24
PostPosted: Sat Apr 10, 2010 11:07 am    Post subject: ui_igo8 Reply with quote
Hi just tried putting the new ui_igo8 onto the sd card but it came as this file already exists do you wish to replace it? do I do this ? or is there something Ive done wrong
