Pocket GPS World :: View topic - XDA II help please!
XDA II help please!
timuk
PostPosted: Mon Mar 08, 2004 10:58 pm    Post subject: XDA II help please! Reply with quote
I've bought a TomTom bluetooth GPS with Navigator 2, and trying to get it to work with an O2 XDA II. I've even downloaded GPS 2.09 as seen in a number of threads. All I get is "GPS disabled" at the bottom of the main screen. If I tap "GPS status" I get a dialogue box with "Unable to launch the GPS control panel."
Any ideas? I'm going to kill myself soon otherwise... Smile
Thanks for any help.
Tim
PostPosted: Mon Mar 08, 2004 11:06 pm    Post subject: Reply with quote
First off (and apologies if I'm way off here) but I thought the XDAII was not currently compatible with Bluetooth GPS receivers at the moment due to some issue with the BT Serial Port Profile?
If I missed an update that has resolved this and you have correctly 'paired' and connected the BT Receiver, then in the GPS Setup Section, have you correctly configured the GPS Type and COM Port and 'ticked' the box to the left to enable these settings?
timuk
PostPosted: Mon Mar 08, 2004 11:14 pm    Post subject: XDA II Reply with quote
I successfully paired the GPS receiver and the XDA II without any problems at all. But I can't see how to get to the "GPS setup section" ... this is probably my problem!!
Tim
PostPosted: Mon Mar 08, 2004 11:28 pm    Post subject: Reply with quote
I'm not sure that being able to 'pair' the two devices proves that the BT SPP issue has been officially resolved, I know that there are workarounds but no official patch. Anyways......
To get to the GPS Set-Up Section, launch TTNav and if in 'Navigator' mode, tap the screen, then select 'More...' and the select 'GPS Status'. To do the same from 'Map' mode select 'File' GPS Status at bottom left.
GPS has three tabs. On the 'GPS' tab you need to configure the GPS Type you have (TomTom Wireless GPS?) and the BT Com Port that the XDA uses.
Once done you 'tick' the box adjacent to save and activate the settings. Whilst you're here move the slider next to the PDA icon to the Right to prevent the XDA from entering sleep mode whilst the GPS is active.
Switch to the Status Tab and a sequence of scrolling black dots between the GPS and PDA Icons indicates successful communication between XDA and GPS.
If all has worked so far then you need to stand outside and get a satellite fix Thumbs Up
timuk
PostPosted: Mon Mar 08, 2004 11:52 pm    Post subject: Thanks! Reply with quote
Very many thanks - all seems fine now. If we were closer I'd buy you a beer :-)
Regards
Tim
AndyCr15
PostPosted: Mon Jul 19, 2004 11:57 pm    Post subject: Reply with quote
I'm getting the same error with my iPaq 3970, Navman sleeve and Tomtom 3...but I'm not sure what to do...
Your fix seems to go right through the problem? Is there anything else that can be done?
TomTom 6 - SPV M5000 and WM6
Garmin Zumo 500 on Honda TransAlp
www.lanarchy.co.uk for LAN gaming near London
AndyCr15
PostPosted: Tue Jul 20, 2004 12:05 am    Post subject: Reply with quote
Might be worth mentioning, I've tried removing Smart ST Pro and installing the navman driver found here.
AndyCr15
PostPosted: Tue Jul 20, 2004 12:22 am    Post subject: Reply with quote
Nevermind, I've found a re-install has fixed it Thumbs Up
22.062 (12 Jun 24)
