Pocket GPS World :: View topic - Ash10's Camera Manager Software
Goto page Previous  1, 2, 3 ... 56, 57, 58 ... 75, 76, 77  Next
PaulB2005
PostPosted: Fri Mar 26, 2010 2:55 pm    Post subject: Reply with quote
The alert distance (timing) you set affects the timing of the first alert.
The number of bongs or alerts you get is down to the unit itself.
kweller
PostPosted: Sat Mar 27, 2010 12:44 am    Post subject: Reply with quote
Thanks. I've just shortened the time to my first alert so that should cut down on the bongs!
Kevin
QX99
PostPosted: Tue Apr 27, 2010 4:05 pm    Post subject: Problems updating Speed Cams with Camera Manager Reply with quote
Camera Manager cannot produce the updated speed camera data. First it show the error message:
"Error opening 'pgpsw-speed-cams-uk.zip' for reading"
followed by:
"Error opening 'output.csv' for reading.
Any ideas?
Barncluith
PostPosted: Wed Apr 28, 2010 10:57 am    Post subject: Reply with quote
Are you using Virgin Media Security? I got the same error messages and traced them to VMS.
QX99
PostPosted: Thu Apr 29, 2010 9:25 am    Post subject: Reply with quote
I'm not using Virgin. I have O2 broadband over a BT line. Thanks for your suggestion though.
I haven't changed any firewall/security settings recently but I'll check them.
BigPerk
PostPosted: Thu Apr 29, 2010 2:31 pm    Post subject: Reply with quote
Is this the first time you have used Camera Manager, or was it working ok up till now? If it's your first time check with the Help file to make sure you seem to be doing it right - eg some people have unzipped the files themselves, whereas I think CM expects to do it itself; also have you got CM pointing at the right directory with the PGPSW files in?
(I expect you know, but the Help file is found by clicking on the CM icon)
(Navigon 70 Live, Nuvi 360)
PaulB2005
PostPosted: Thu Apr 29, 2010 2:39 pm    Post subject: Reply with quote
Have you got the latest version (3.0)??
When did you last successfully use CM?
QX99
PostPosted: Thu Apr 29, 2010 3:08 pm    Post subject: Reply with quote
Paulb2005 and BigPerk,
I have been using CM successfully for about a year and did upgrade to the latest version, also successfully. This has just started with the last update.
PaulB2005
PostPosted: Thu Apr 29, 2010 3:28 pm    Post subject: Reply with quote
Have you tried deleting the 'pgpsw-speed-cams-uk.zip' file and making it generate a new file?
Have you tried opening the 'pgpsw-speed-cams-uk.zip' at all?
Just wondering if you have corrupt download.
BigPerk
PostPosted: Thu Apr 29, 2010 5:26 pm    Post subject: Reply with quote
Another thing to try is to make sure you have deleted ALL previously loaded camera files completely, so that you do the new download into an empty folder (not sure if this WILL help at all, but just wondering if old, obsolete, file formats might upset the new version of CM in some way?)
Ash10
PostPosted: Thu Apr 29, 2010 9:01 pm    Post subject: Reply with quote
I haven't received any other reports, so I'm guessing that this problem is specifc to QX99's setup - I PM'd him earlier with a couple of things to try... Thumbs Up
As Barncluith says above, we did manage to track down a problem with Virgin Media Security, which appeared to be meddling with downloaded files - nice... Shocked
QX99
PostPosted: Fri Apr 30, 2010 10:15 am    Post subject: Reply with quote
All seems to have been resolved now with some prompt and very welcome help from Ash10 - thank you!
The problem seems to have been that the files downloaded/created by Camera Manager 3 disappeared from my POI directory (Why? I have no idea - very strange!). Restoring an old version of the pgpsw-speed-cams-uk.zip file seems to have "kick-started" things again.
AclassofitsOwn
PostPosted: Mon Jun 21, 2010 9:23 pm    Post subject: camera manager options greyed out - help please Reply with quote
Have downloaded camera manager and started it up. What I have is:
notification that 'poi directory is not set'
options under the 'directories', 'options' and 'settings' are nearly all greyed out and thus inaccessible.
Is it finger trouble/what can I do to sort?
Many thanks
PaulB2005
PostPosted: Mon Jun 21, 2010 9:35 pm    Post subject: Reply with quote
Have you installed POILoader? If not, do so.
Have you used it even once? If not, do so (uploadone of the free POI files from PGPSW)
Then CM can get the info it needs....
AclassofitsOwn
PostPosted: Tue Jun 22, 2010 5:15 am    Post subject: Reply with quote
Paul,
apologies, I think have it sorted now - definitely 'finger' and 'too long a day' trouble!!
Page 57 of 77
22.123 (18 Dec 24)
