marcus29359 Occasional Visitor
Joined: Oct 01, 2009 Posts: 31 Location: bolton and rhyl
Posted: Fri Mar 19, 2010 8:38 pm Post subject: Text to Speech (on a ONE?) |
Hi all. This is my first post even though I have been a member for some time so I hope someone can help.I have a tomtom one IQ routes. Is it possible to make it use tts as I had a 720 (which packed up ) and really miss this feature.I dont think it can be done but you might know different.Thanks. |
wetsleet Occasional Visitor
Joined: Oct 13, 2005 Posts: 23 Location: Stourbridge, UK
Posted: Fri Mar 19, 2010 10:58 pm Post subject: |
don't know about tomtom, but since this is the Copilot forum, you may as well know that Copilot 8 can do TTS - it's about a £4 add-on - but it's not that great, in that the one and only English TTS voice offered is a slightly asthmatic female who speaks too quickly and quietly, runs words together and swallows the last syllable. |
Gmt_Plus1 Lifetime Member
Posted: Sat Mar 20, 2010 10:56 am Post subject: |
wetsleet wrote: | don't know about tomtom, but since this is the Copilot forum, you may as well know that Copilot 8 can do TTS - it's about a £4 add-on - but it's not that great, in that the one and only English TTS voice offered is a slightly asthmatic female who speaks too quickly and quietly, runs words together and swallows the last syllable. |
wetsleet, thank you for my first "belly laugh" of the day. nearly in tears trying to imagine your "asthmatic female".
marcus29359 - Not sure about TTS on ONE either but wetsleet is correct, you may get a better response if you post your question in the TomTom forums. Re ask your question with a link to this page and I'm sure it shall be moved over by one of the Mods. |
Posted: Sat Mar 20, 2010 12:12 pm Post subject: |
Moved to the TomTom PND forum..... |
Posted: Sat Mar 20, 2010 12:43 pm Post subject: |
I think forum member Gee-Pee has a One with TTS as I recall, it was supplied new with the files pre-installed, and will be using Vocalizer rather than Loquendo for the TTS - Mike |
AndyVaughan Lifetime Member
Joined: Apr 13, 2006 Posts: 1500 Location: Rossendale
Posted: Sun Mar 21, 2010 11:41 am Post subject: |
AFAIK the TT ONE IQ Routes in the UK does not normally come supplied with TTS.
Even installing a TTS Navcore and the necessary voice files will not enable it.
Getting it working is well beyond the scope of this forum. |
Posted: Thu Mar 25, 2010 8:04 am Post subject: tts |
Thank-you for your replies (sorry for posting in wrong area).I didnt think it was possible but it was worth asking.Thank-you all again. |
Posted: Thu Mar 25, 2010 4:25 pm Post subject: |
Is it a ONE IQ Routes or a XL IQ Routes?
Which Navcore version are you running at the moment? 9.026?
Let me know and I might just put you something together to try - you never know, it might work! |
Posted: Thu Mar 25, 2010 7:52 pm Post subject: tts |
Hi Andy. I have a tomtom one iq routes and app. 9.026.I hope this helps.Thanks. Marcus. |
Posted: Thu Mar 25, 2010 10:05 pm Post subject: |
Leave it with me a day or two to extract the necessary files from the 9.026 ttsystem file and I should be able to put something together. |
Stampy72 Regular Visitor
Joined: Jun 19, 2008 Posts: 192 Location: near Stamford, Lincs
Posted: Fri Mar 26, 2010 12:12 am Post subject: |
Better do a FULL BACKUP just in case......  _________________ XL LIVE IQ Routes (Europe)
App 9.465.1074274.2
OS 842337 (2025, 27/9/2012)
GPS v1.20, Boot 5.5138
Map : "Europe_North" v 900.4602 |
Posted: Fri Mar 26, 2010 7:59 am Post subject: tts |
I have done a full backup NOT with tomtom but with windows vista (drag and drop). |
Posted: Fri Mar 26, 2010 12:44 pm Post subject: |
Download this file - extract it and there is a readme.txt and another RAR file inside.
Follow the instructions in the readme.
This SHOULD enable TTS on ONE (2009) IQ Routes, XL (2009) IQ Routes and XL LIVE (2009) IQ Routes editions. You MUST be running 9.026 - links for the ONE and XL versions as well as Kate Loquendo TTS voice are in the readme. If you have a widescreen model you MUST use the XL 9.026 release or it will crash - there are some file differences between the two.
It MAY work on other models - I can only test on a XL LIVE though. The files have been extracted from Navcore 9.026 so don't try it on a different version. This will upgrade your bootloader to 5.5136 (if it isn't already) which is the standard bootloader for these devices (XL LIVE is currently at 5.5138 so will not be upgraded). If you attempt to use this on an older ONE or XL and don't want to upgrade the bootloader (recommended not to) then delete the system file from the root of the TT after installing the Navcore and before rebooting.
This is all at your own risk - make sure you have a full backup before starting.
This is not a hacked Navcore - it is the original TT navcore with a startup script to amend the hw_loquendo variable. To speed the devices up I copy some files to RAM before running them - please leave feedback as I can disable that feature as it makes the device slower to boot BUT it should run faster. I can amend the script so that all fies are run from the Flash if people find the boot time is too long, but the device will run slower.
Not sure if this will work on a 32Mb version - let me know.
Edit - link removed
Posted: Fri Mar 26, 2010 12:58 pm Post subject: |
Forgot to mention
Nav 9.026 has the navigate to postcode - anywhere option back!
Should please DennisN (as long as it actually works) |
dgreensuperhoops Occasional Visitor
Joined: Nov 15, 2007 Posts: 49 Location: Leighton Buzzard Beds
Posted: Fri Mar 26, 2010 10:28 pm Post subject: |
Hi I have been reading this thread with interest as I have an XL live IQ routes and would love to have tts again. I used to have tts on my 730 before I had to get rid of it and miss it. However my app no is showing as 8.419. Is it possible to upgrade this so I can try to get tts? Thanks |
