crypticx Occasional Visitor
Posted: Thu Mar 11, 2010 5:05 pm Post subject: european speed cams |
just a quickie can you get the european speed cams from pocket gps.or if not weres the best place to get them.thanks in advance |
inthe128 Pocket GPS Verifier
Joined: Nov 27, 2005 Posts: 130 Location: Czestochowa, Poland
Posted: Thu Mar 11, 2010 5:33 pm Post subject: |
Yes you can get them from PGPSW, you can download the Euro cameras from the same place you download the UK ones _________________ in the 128 |
Posted: Thu Mar 11, 2010 6:17 pm Post subject: |
CALLED MYSELF TO HAVE LOOKED.WILL GO BACK AND HAVE ANOTHER LOOK.ALL I SAW WAS OV2 FOR TOMTOM .OK THANKS inthe128.CHEERS |
Posted: Thu Mar 11, 2010 6:21 pm Post subject: |
YOU WERE RIGHT M8 FOUND THEM .CHEERS FOR THAT  |
Posted: Thu Mar 11, 2010 6:29 pm Post subject: |
You are most welcome, I can vouch for the ones in southern Poland but on my travels around Europe in general they are as good as the UK ones. _________________ in the 128 |
lancedavies Pocket GPS Verifier
Joined: Mar 30, 2008 Posts: 8 Location: 31880 LA SALVETAT SW FRANCE
Posted: Mon Mar 15, 2010 11:37 am Post subject: |
Also all those in SW France are OK |
Posted: Mon Mar 15, 2010 12:18 pm Post subject: |
I have found the euro ones to be fairly good, but as members are doing the sighting and verifying sites then more out the way places or routes will suffer. Some regions are installing cameras at a rate of knots, other countries not so much, so some variables in cover is bound to happen. As its a UK site with the most members living in the UK, then you would expect the database to be solid.
I vary my routes as much as possible in Poland and catch new sites or update, but I think its just me and a donated database doing the southern bit, I found the Euro database pretty good within Germany, Holland and Scandinavia, but I have my eyes open as well, its always changing out there. _________________ in the 128 |
BigPerk Frequent Visitor
Joined: Sep 06, 2006 Posts: 1618 Location: East Hertfordshire
Posted: Mon Mar 15, 2010 12:34 pm Post subject: |
That's encouraging - I hadn't realised how reasonably accurate and comprehensive the Euro cams were. Congrats to the spotters/verifiers - I'll definitely be loading them for the summer (I had been thinking I'd have to fork out for one of the continental commercial offerings).
I'll try and do my bit on the way down to Garda! _________________ David
(Navigon 70 Live, Nuvi 360) |
Posted: Mon Mar 15, 2010 12:50 pm Post subject: |
Its part of the same package, I had it in the Uk then moved to Poland and let the sub go, but after a while saw some PL cameras so subbed again and soon got my first camera in 30mins
I would say on the route you would take the database will be pretty good, if you were to go somewhere a little less normal, then cover will not be as good. _________________ in the 128 |
DogSlow Occasional Visitor
Posted: Fri Mar 19, 2010 10:14 am Post subject: |
There's also a French government (I think) site, which shows the location of all fixed French Gatsos. A look on there as you plan your route can alert you to possible problems on your journey. I'm pretty sure that all these are on the PGPSW database by now though.
The site is at
http://radars.securite-routiere.gouv.fr/metropole
Enjoy your trip .
John |
markybtenerife Lifetime Member
Posted: Mon Mar 22, 2010 8:37 pm Post subject: |
i am going to france soon
i normaly use the uk speed zoned ones. do i need to choose the eur zoned ones as well.
do the eur ones include the uk cams . if not, can i use the uk and eur ones in the map folder together
and will the voice alerts work with the euro cams
thanks |
Posted: Mon Mar 22, 2010 8:50 pm Post subject: |
markybtenerife wrote: | i am going to france soon
thanks |
You can place both databases into your map folder, you would need to set the alerts up as you did for the UK version, there is a Euro OGG file which reads out in KPH if thats how you did yours or however you set up your UK alerts is the same for the Euro ones. _________________ in the 128 |
Posted: Mon Mar 22, 2010 9:10 pm Post subject: |
thank you ill have a play with the ogg file and cams |
TonyIshUk Occasional Visitor
Posted: Wed Mar 24, 2010 10:07 pm Post subject: |
Just to add that (I think) there is only one voice which is Kate (oggs) for eurocams and you will need to copy & rename some of the pmobile oggs to complete the set.
There are also some ""holes" in the ogg set, there are more speed camera definitions than "oggs"
You may need to reduce the length of name of the files because when viewing the POIs in the TT the names all look the same and are cut off.
I use http://www.bulkrenameutility.co.uk , great little utility
Rgds |
