xda Lifetime Member
Posted: Sun Jul 18, 2004 12:21 pm Post subject: Speed Camera in the North Sea |
Hi Dave,
You seem to have one of your cameras located 135 miles out into The North Sea off Grimsby
Gatso: 3779 at 3.3469 53.4716 I think it should read -3.3469
_________________ Graham.
Map: Europe V910.4892
Nokia 925 Windows 8 |
Mearns Lifetime Member
Joined: 24/08/2003 18:17:58 Posts: 162 Location: Aberdeen, Scotland
Posted: Sun Jul 18, 2004 1:23 pm Post subject: |
There must be a POI black hole off Grimsby. A while back I started a list of Saab dealers by inputting the dealer post code into Autoroute and reading off the Lat/Long. In TTN3 the one in Grimsby has appeared out in the North Sea as well!
xda - if you plot the longitude with a minus sign as you suggest then that position puts you in the Irish Sea about 17 miles WNW of Liverpool. _________________ Tony
nuvi 2460LT plus Brodit mount |
Dave Frequent Visitor
Posted: Sun Jul 18, 2004 3:26 pm Post subject: |
Don't forget that if AutoRoute or any application says West then TomTom and a lot of apps will only read East, so you need to put the East as a Negative, so if it's showing 1.23456 then make sure it's -1.23456 if it's west of Meridian. If it's east of Meridian then it should be a positive.
Grimsby is definately west of Meridian unless you are along the south easterly point of Kings Road then it becomes East. |
xda Lifetime Member
Posted: Mon Jul 19, 2004 3:34 am Post subject: |
Mearns wrote: | There must be a POI black hole off Grimsby. A while back I started a list of Saab dealers by inputting the dealer post code into Autoroute and reading off the Lat/Long. In TTN3 the one in Grimsby has appeared out in the North Sea as well! |
I've done a few using Autorote to get the Lat/Long but Autoroute position locator doesn't give you East as a - which needs to be put in for use with TT. Made that mistake myself.
Mearns wrote: | xda - if you plot the longitude with a minus sign as you suggest then that position puts you in the Irish Sea about 17 miles WNW of Liverpool. |
Must admit I didn't check it, so the longitude for "GATSO 3779" is totally wrong. _________________ Graham.
