Retty Frequent Visitor
Posted: Wed Mar 10, 2010 3:59 pm Post subject: Out of memory problems? |
Could someone else confirm that the following legitimate postcode gives an out of memory error (CE 4.2 PDA device) using iGO8:
LU6 2LF |
Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Wed Mar 10, 2010 6:29 pm Post subject: |
Unnamed road near Dunstable. On the map it points to a gap in a road which looks like it was once one maybe. _________________ Formerly known as Lost_Property
And NO that's NOT me in the Avatar. |
M8TJT The Other Tired Old Man
Posted: Wed Mar 10, 2010 7:21 pm Post subject: |
Gives the OOM error on mine too. LU6 2LG is OK
CE4.2 PNA device |
Posted: Fri Mar 12, 2010 3:24 pm Post subject: |
M8TJT wrote: | Gives the OOM error on mine too. LU6 2LG is OK
CE4.2 PNA device |
It seems to be software version specific (not a problem on early 8.3.2) and it does not depend on size of poi or speedcam files; when it does happen it's rural postcodes with no house numbers that trigger it; some do work though. The problem appears when exiting the house number entry screen (pressing "done" without an entry) and not on routing.
Manually adding the postcode entry to the "history" file (editing the file or using a file from an earlier working version) and selecting it from there instead of inputting the postcode normally works fine. It's hardly a workaround but it shows something. Not sure what.
It may suggest that the problem is less to do with hardware memory limits and more to do the buggy code. |
Posted: Fri Mar 12, 2010 9:12 pm Post subject: |
CE4.2 PNA device |
Sorry, I meant "CE 4.2 PNA" device too (not PDA) ;-) |
johalareewi Lifetime Member
Joined: Jul 15, 2009 Posts: 50 Location: Hampshire UK
Posted: Mon Oct 17, 2011 6:08 pm Post subject: |
I have had the out pf memory error too with rural postcodes and iGo 8 but it has been OK if I put in the town and street. |
