Pocket GPS World :: View topic - Fortuna clip-on bluetooth gps
bak
PostPosted: Sat Jul 17, 2004 8:50 pm    Post subject: Fortuna clip-on bluetooth gps Reply with quote
recently purchased fortuna bluetooth gps from nex_gensales on e-bay.Worked ok till yesterday,problem i have is that when i switch the gps on i only get the green led power light, no indication of gps seraching for satellites and also i cannot connect to my pda [ipaq2210] I have tried removing battery and switching modes but still no joy.Would appriciate any help in this matter.
hijacker
PostPosted: Sat Jul 17, 2004 10:01 pm    Post subject: Reply with quote
That's a new one to me. Sounds like it's given up the will to live.
How long did you remove the battery for? If it was at least 5mins then it should have performed a hard reset.
If there is still no light other than the battery I would organise a replacement from NexGenSales.
TT GO 1005
salako
PostPosted: Tue Jul 20, 2004 8:59 am    Post subject: Reply with quote
Strange!! I was just about to post on the exact same problem. It was fine until yesterday afternoon and now no middle satellite light at all. anyone else experienced the same problem?
PostPosted: Tue Jul 20, 2004 9:52 am    Post subject: Reply with quote
If you are trying to get back to original factory settings you should remove the battery for at least 24 hours as these receivers use super capacitors to power the memory. Most manufacturers recommend a 24-48 hour disconnect.
The normal reason to require this is when the internals of the GPS have got messed up and the GPS has stopped talking to the BT, but most devices have code to protect this happening, so I suspect this is not the case here.
I would get in touch with your retailer and see what advice they can give.
22.062 (12 Jun 24)
