Pocket GPS World :: View topic - Mapsource - joining 2 WP with no path in between
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Garmin Handheld GPS Receivers
deeegeee
PostPosted: Tue Mar 02, 2010 7:43 pm    Post subject: Mapsource - joining 2 WP with no path in between Reply with quote
I am using MapSource v6.15.11 with the openstreetmap 'GB+Contours' map.
I am creating a walking route based on footpaths. I have a path going into a car park and a second path leaving the car park but with no path in between these points. How can I get MapSource to join up these two points, which are around 200m apart? At the moment it calculates a route that goes around the paths and roads of several kilometres. Thanks David
dales
PostPosted: Tue Mar 02, 2010 9:51 pm    Post subject: Reply with quote
Edit...Preferences...Routing...Use Direct Routes.
Then back to the map sidebar, routes tab, Rclick on route name...Recalculate route.
Dales.
nuvi 2599LMT-D, oregon 700, basecamp, memory-map.
deeegeee
PostPosted: Wed Mar 03, 2010 7:28 pm    Post subject: Reply with quote
Dales.
thanks - the challenge is that I need to use 'Auto-Routing' and 'Direct Routes' on the same route that I am creating due to the non joined up paths, e.g. where they cross car parks. I realise that this would not be a problem if I was using proper OS maps but it looks like I will have to live with it with the opensourcemap. I can create separate routes and 'jump' between them. David
Kritou
PostPosted: Fri Mar 12, 2010 9:23 am    Post subject: Reply with quote
Howsabout .... create the route up to the first problem WP the go to the map panel in the sidebar and deselct the green tick in "Include Route Calculation Data", add the second WP to your route then reselect the tick
Just a theory and of course ETAs etc would not be valid
ps I would like to know more about using Openstreetmap on a GPSR and Mapsource - where do I start reading?
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Garmin Handheld GPS Receivers All times are GMT + 1 Hour
22.062 (12 Jun 24)
