bandk Occasional Visitor
Posted: Sun Feb 28, 2010 12:25 pm Post subject: Which file to save? (for Favourites etc.) |
TT have emailed me to let me know that new maps are available. Now last time I did this I lost all my saved poi's, favourites,voices,cams etc. Basically I ended up with a TTXL with a clean install.
Somebody did mention how to avoid this by saving one of the files with the required info within it, can somebody tell me which file that was please. |
![](modules/Forums/images/avatars/gallery/Sphere_animated_small_neg2.gif)
Posted: Sun Feb 28, 2010 1:38 pm Post subject: |
MapSettings.cfg which you will find in the old map folder, it might make the unit conatantly re-boot if you put the old MapSettings.cfg file in to the new map folder, connect the device to Home and alter a favourite and it should be OK after that - Mike |
TonyIshUk Occasional Visitor
MARViN2003 Regular Visitor
![](modules/Forums/images/avatars/1583696816438a1928a8528.jpg)
Joined: Nov 27, 2005 Posts: 132 Location: Stroud, Gloucestershire
Posted: Fri Mar 05, 2010 12:12 am Post subject: |
If you convert you favorites into a POI category, you won't need to faf about when you do a map update, as they won't get overwritten. |
