Pocket GPS World :: View topic - What could Crux View and CEmonitor do to my Clip-on?
TC
PostPosted: Fri Jul 16, 2004 10:11 pm    Post subject: What could Crux View and CEmonitor do to my Clip-on? Reply with quote
Now that I have successfully upgraded the firmware in my Clip-on and can now see the firmware version - thanks to all those who helped me in the 'Firmware upgrade fro Xtrac v2???' thread - what could these GPS tools do to my unit?
For instance I could change the values for GGA, GLL, GSA, GSV, RMC, VTG but would it screw up my unit? Does it even work with the Clip-on? Why would anyone want to change these values - would it give better performance? I realise these tools aren't specifically designed for the Fortuna, but I'm just a bit curious.
Lastly if I switched the unit to Sirf Binary protocol (Crux View) what would that do and why would you do it?
Ipaq 2210
Fortuna Clip-on [Xtrac V2]
Tom Tom Navigator 3
Memory Map
PostPosted: Sat Jul 17, 2004 5:25 am    Post subject: Reply with quote
As long as your unit is using a standard SiRF chipset these tools should work fine. Changing the NMEA sequence frequency is not really necessary though, unless one of your programs explicitly needs GSA or GSV
Switching to SiRF binary protocol is academic. There is no real use for that, except that the data stream is a little less redundant. But even with NMEA 4800 there is pleanty of time to update all the sequences once a minute. There is no real reason to switch to SiRF.
22.062 (12 Jun 24)
