Pocket GPS World :: View topic - Strange 950 lock up
Strange 950 lock up
Flinx
PostPosted: Sun Dec 20, 2009 1:02 pm    Post subject: Strange 950 lock up Reply with quote
Travelling along the A46 from Newark to Leicester, on the duel carriageway near Six Hills are 2 fairly new speed cameras. As I approached these I realised that my 950 had locked up (no warnings, frozen screen etc) which required a reset to clear. 4 hours later on returning along the same road the same happened at exactly the same point!
Anybody else had an experience like this?
Flinx
Eagle15
PostPosted: Mon Dec 21, 2009 5:50 am    Post subject: Reply with quote
My 950 freezes at times. It did it 7 times in one day so I raised an incident with TomTom support. Their answer was to Back it Up, Format the Disk and then rebuild it (they sent me a 6 page set of instructions). I did this (took a couple of hours), and it now only freezes about once a day. I have no idea if this is related to Cameras or not.
tedkay
PostPosted: Tue Jan 12, 2010 11:33 am    Post subject: GO 950 Freezing - Me Too ! Reply with quote
GO 950 LIVE HANGING.
I've had the device for a month now and over the last couple of weeks the unit has started to hang after about 30 miles, or every half hour or so. Restarting the unit gets it moving again, but then it hangs again after another half hour, and the cycle continues like this.
I have reset the device and (with great trepidation !) installed the latest software update but the problem persists. The unit is fully charged and connected to power when the problem occurs.
Naturally the freeze-up usually happens just when I need the thing most, like when I'm approaching a junction or a roundabout !
Waiting to see what TT tech suggest but I won't be wasting my time doing any lengthy re-installation procedure which according to the previous poster doesn't work so I suppose the unit will have to go back for replacement. I'll see what they say though ...
TED
"If at first you don't succeed; call it version 1.0"
Flinx
PostPosted: Tue Jan 12, 2010 4:42 pm    Post subject: Reply with quote
I installed the latest software update too and, touch wood, it hasn't hung since! The A46 problem above still persists but instead of the 950 hanging it seems to slow down and then jumps. I must admit that since installing the software update the 950 seems much smoother on the screen refresh rates.
Flinx
AndyVaughan
PostPosted: Wed Jan 13, 2010 10:33 pm    Post subject: Reply with quote
Have either of you tried a clearflash? It may help.
http://tomtom.com/6178
Flinx
PostPosted: Thu Jan 14, 2010 5:09 pm    Post subject: Reply with quote
Have downloaded and will try this weekend.
Flinx
AndyVaughan
PostPosted: Thu Jan 14, 2010 10:41 pm    Post subject: Reply with quote
Another thing worth trying is perform a full Windows Explorer backup of your device. (See FAQ)
Then format the internal memory as FAT32 - do a full format.
Now copy back your backup to your device. As Windows transfers the files it does it file by file, so it has the effect of defragmenting the internal memory - i.e. the very large files in your map folder will occupy continuous memory space, not be split all over the memory in smaller chunks.
I know in theory that you do not need to defrag memory or flash cards as you do hard drives, it seems to help slightly with juddering map problems.
Brierls
PostPosted: Sun Feb 14, 2010 12:40 am    Post subject: Reply with quote
My 950 LIVE is locking up quite regularly, in fact I haven't made my (current) weekly commute to Weybridge (220 miles or so) without it locking up at some point.
If I'm quick to notice that its locked (the screen locked, but voice instructions still , a simple tap on the screen takes me to the menu, and pressing back gets it functioning correctly again. If I'm not so quick to notice, tapping on the screen doesn't appear to do anything, but the unit reboots after 30 secs or so.
I'll try the flashing etc that has been suggested above, but if anybody else has suggestions on what to try, what has worked for them etc, then please let me know!
TomTom GO 950 LIVE
MrT
PostPosted: Sun Feb 14, 2010 9:31 am    Post subject: Reply with quote
The screen locks happen on the x40 range as well and have been reported to TomTom many times.
Drivelux
wilfuerdo
PostPosted: Sun Feb 14, 2010 8:50 pm    Post subject: Reply with quote
Hi, I purchased a 950 to replace my 920T in November or 2009.
Aswell as other issues, My 950 locked up every 30 or 40 minutes (screen froze) I had to do the same restart.
I formatted, clearflash, back up/restore everything i read about but to no avail.
i was subscribed to PGPSW cameras but ofcourse didnt want to use, wanted to try the LIVE services version.
I installed the PGPSW cameras, disabled the TomTom ones and hey presto! PERFECT. no lock up in a month.
LIVE services just become expensive then...
1. cameras lock up the device & are not accurate
2. Weather is so badly wrong
3. HD TRaffic is good when working
4. Google search i find unreliable.
Wish I had stuck with the 920T & RDS to be honest
Please disable tomtom camera alerts and test, but mine works a treat.
Andy
Brierls
PostPosted: Mon Feb 15, 2010 12:40 am    Post subject: Reply with quote
When you say disable TomTom Speed Camera's, do you mean uninstall them?
I'm not being pedantic, the reason I ask is I've been running with only PGPSW camera alerts since I subscribed (I uninstalled TomTom Speed Camera's via Home), so I may have the same symptoms but different issue.
TomTom GO 950 LIVE
PostPosted: Mon Feb 15, 2010 9:20 am    Post subject: Reply with quote
I have seen issues where the TT Safety Cameras cause the device to lock up but I thought it was French cameras, but then again I might be wrong, if removing the TT cameras resolves the issue its an easy fix - Mike
wilfuerdo
PostPosted: Mon Feb 15, 2010 10:27 am    Post subject: Reply with quote
I didnt uninstall mine, I just stopped the alerts on the TT safety camera warnings, I now just have the PGPSW cameras as POI.
22.062 (12 Jun 24)
