apples24 Occasional Visitor
Posted: Thu Jul 15, 2004 9:19 pm Post subject: please help newbie, tomton instalation, maps cant be found? |
ok id be extremely greatfull for some help
tomtom has just been installed on my 5450 , i launch it and it says no maps found, i loaded the uk map 92mb onto the sd storage card but its still not finding them? is there a way to set it up?
when i go into .... active sync explore/ pocket pc/ storage card i can see it there
its a 264mb card so should have plenty room |
lbendlin Pocket GPS Staff
Posted: Thu Jul 15, 2004 9:35 pm Post subject: |
make sure the map directory ends with "...Navigator Map" . Rename if necessary.
If it still can't find the map, use a registry editor to help it.
\\HKCU\Software\TomTom\TomTom Navigator\Maps
The key LastMap needs to point either to the map name or the physical directory. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Thu Jul 15, 2004 9:42 pm Post subject: |
checked all files on my storage card and yes they end in map and great britain etc
there dat files? |
Posted: Thu Jul 15, 2004 9:55 pm Post subject: |
There have to be multiple files
For example
CLINE.DAT
CNAME.DAT
CNODE.DAT
FACES.DAT
MAPINFO.DAT
POI.DAT
SETUP.DAT
but also other files like (mapname).pna etc. If you open the map CAB file with WinZip then you see them all. _________________ Lutz
MrT Frequent Visitor
![](modules/Forums/images/avatars/gallery/065.gif)
Posted: Fri Jul 16, 2004 7:34 am Post subject: |
This seems to be a problem when TT is started by TT Wizard. It always (for me) reports no maps. I had to re-create the shortcut to the TT exe file to get it to work.
The TT Wizard has never worked for me. The traffic wizard works but it only a tutorial. |
tloram Occasional Visitor
Posted: Fri Jul 16, 2004 7:25 pm Post subject: |
I have literally just recieved and installed TomTom3 for my Hp H1930. I installed the full great britain map to my 512 SD CARD.
When I start up TomTom it tells me I need to install a map!
What the hell is going wrong here?
![Sad](modules/Forums/images/smiles/icon_sad.gif) |
Posted: Fri Jul 16, 2004 9:05 pm Post subject: |
Have you looked into the registry ? _________________ Lutz
AndyWilson Occasional Visitor
Posted: Sun Jul 18, 2004 12:36 pm Post subject: |
I've seen lots of stuff here about not using TT wizard to launch TomTom3, changing registry locations etc etc but I had the "no maps" problem with my clean install of TT3 and I opted for the simple solution, just move the map folder into the My Documents folder of the storage card.. |
Posted: Mon Jul 19, 2004 11:13 am Post subject: |
Hi guys,
Just a note to say that I have been in touch with TomTom official support and have solved my problem...here is my complete communication log! >
Quote: | Customer 16/07/2004 08.29 PM
I have just recieved and installed TomTom Navigator 3 UK. I installed the GB map (entire map) to a 512 SD CARD (Viking Interworks 512Mb) using a card reader (PQI).
I have verified that the files are on the card at the top level under a directory called "Great_Britain Navigator Map".
When I start up TomTom for the first time it tells me that I need to install a map and then quites back to the PDA menu screen.
This is a brand new PDA so I don't have much other software on it at the moment.
What do I do? |
Quote: | Response 16/07/2004 08.33 PM
Dear Mr Loram,
Format the card with the reader and then reinstall the full GB map again. Should the same problem exist again then delete the GB map and then install the smallest map (16mb) to the flash card and see if the problem is cured. If it is then tell us the country of manufacture of the SD card.
We hope to have answered your question to your satisfaction.
With best regards,
The TomTom Customer Support Team |
Quote: | Response 16/07/2004 08.34 PM
Dear Mr Loram,
There is one more thing. Do you actually have an HP 1930?
All of the HP 19XX series of IPAQs to include the HP IPAQ 1940 do not have any type of in built serial port so these models will not work with ANY wired GPS receiver from any GPS manufacturer. The first model above the 19XX series that will work with a wired receiver is the HP IPAQ 2210. The HP 1940 can work with a bluetooth GPS only.
With best regards,
Quote: | Customer 16/07/2004 08.43 PM
I have a HP 1930 yes. It came as part of the Kirrio ViaMichelin GPS package. The wired GPS reciever plugs into the car cradle which itself plugs into the PDA via the bottom port...
This is the package I have >
http://www.kirrio.com/uk/products/viamichelin_gps_navigation_pack/index.php?cat=1&id=3
I found the ViaMichelin software lacking so I decided to purchase TomTom instead...
Are you suggesting that TomTom will not work with the H1930? Still, this shouldn't stop the maps from being found in the first place should it?
If so can I get a refund? |
Quote: | Customer 16/07/2004 08.49 PM
I have just formatted my Viking 512 Mb SD CARD and installed the 16Mb map.
TomTom navigator now starts up ok and finds the map.
I will try putting the Full Great Britain map on again and see if it manages to find this map... |
Quote: | Customer 16/07/2004 09.11 PM
I have installed the full Great Britain map on my Viking 512Mb SD CARD after formatting and now it works ok.
Thankyou.
I will now attempt to connect my PDA up to my car GPS kit and see if it works with TomTom...
Is there any particular thing I should try first to get it working with my wired GPS reciever? |
Quote: | Customer 16/07/2004 09.19 PM
OK.
I have installed my PDA in my car cradle and change the GPS setting to "Serial on USB" and everything works perfectly.
TomTom Navigator 3 works with HP H1930 with wired GPS (through serial on USB)!
All problems are solved now. Thanks for the support.
Maybe you should add the HP H1930 to your list of compatible PDA's... |
THE END
:D
Everything works perfectly and I have CheckPOInt 3.2 installed and notifying me of speed cameras etc. Excellent. |
Zeena Regular Visitor
![](modules/Forums/images/avatars/44972082741bc07881696e.gif)
Posted: Wed Nov 17, 2004 6:52 pm Post subject: |
OK...
Great tip.
So you choose the "Serial on USB".... but what do you choose in the driver list above in TomTom GPS ? _________________ Gunnar Nystul, Forum Admin, TomTom Forum Norway and Nystul Navigasjon |
