Pocket GPS World :: View topic - POI Help
POI Help
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Sygic McGuider/Mobile Maps
superleeds
PostPosted: Thu Feb 11, 2010 3:31 pm    Post subject: POI Help Reply with quote
Istalled maps 9 on n95 8gb and on nokia 6220 classic
Poi etc all work fine on 8gb
but on 6220 the icons wont show for speed alerts etc the sounds are there but no icons I am using the same icons as n95 ie 44 x44 8 bit but i cannot the icons to show on the 6220 ..any ideas thank you..
scarymonkey
PostPosted: Sat Feb 13, 2010 2:09 pm    Post subject: Reply with quote
Are you using the same UPI files between both? If you create the UPIs using any scripts then the bmp file needs to be just the filename and not a path unless that path exists in the res\icons directory as well.
BackSeat
PostPosted: Sat Feb 13, 2010 4:54 pm    Post subject: Reply with quote
The UPI file format is not one of Sygic's strengths. I have (today) sent a list of suggestions to Sygic about Mobile Maps on Android, and one suggestion was:
Code:
Please document the UPI file format. The current conversion utility isn't very robust, and if you documented the format then the work of developing a better conversion utility would be done for you by the community. It would also be ported to Linux (the platform I use), and wouldn't cost you anything. Better service to customers, no cost to you (other than documenting the format). How good is that?
If I get a reply, other than a thank you, I'll post it here.
Happy to post the other suggestions I made to a new topic if there's any interest.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Sygic McGuider/Mobile Maps All times are GMT + 1 Hour
23.054 (28 May 25)
