planetnine Regular Visitor
Joined: Dec 11, 2006 Posts: 93 Location: Lincolnshire, England.
Posted: Fri Jan 22, 2010 1:36 pm Post subject: |
I suppose it might be a physical dimension tolerance thing, where your card works in other Active-10 units and all other cards work in your unit, but not your card in your unit.
Sounds very frustrating. I've had signal plugs like that, where one combination would not work properly together and caused errors.
Let us know the outcome if you do send it back Mike... _________________ planet nine
Lincoln, UK. |
stevendunn99 Occasional Visitor
Posted: Sat Jan 23, 2010 3:20 pm Post subject: |
I had the same problem. Post 1.4 upgrade, one of my cards (out of 3) would no longer be seen on boot up but worked fine after removing and re-inserting. The other cards were fine. 1.42 did not solve either so I assumed that it was th card but Satmap insisted that I update the platform first. They sent me a new platform SD card foc to try, which arrived today, and now everything seems to be fine. |
MikeofDorset Occasional Visitor
Posted: Sat Jan 23, 2010 4:19 pm Post subject: |
stevendunn99 wrote: | They sent me a new platform SD card foc to try, which arrived today, and now everything seems to be fine. |
Yes, this was a recognised problem and obviously one that was solved with the platform upgrade. Unfortunately my problem doesn't seem to fall into any logical category. I can't for example even get it working by inserting and reinserting the card. Despite having all the software upgrades of v1.42 and 09.02.21 my card still stubbornly refuses to be recognised. Although on just one occasion after the upgrades it did work (as it occasionally did previously), so I suppose it still can be classified as intermittent.
On Satmap's advice, I am sending both map card and unit back to them on Monday. I'll post the result of their examination when known. |
Posted: Sat Jan 30, 2010 1:54 pm Post subject: |
Further Update to Map Problem Saga:
Fantastic service from Satmap - posted unit and map card to Satmap on Monday, and have just received them back in this morning's post. I've since spent the rest of the morning testing and retesting, and the hitherto non-recognition problem with this one map card (OS GB South) has now apparently been resolved.
However, I'm no nearer getting a definitive answer as to what caused the problem, or indeed why I apparently had two consecutively 'duff' map cards, as that is what I can only conclude lay at the heart of the ongoing problem. Quoting from Satmap's report, they say:
Quote: | GB South map card has been reproduced on a new card by the mapping team and it's now being detected by the unit. Have also reinstalled 1.42 software on unit.
Which I'm sure is exactly what they did to the map card on the first occasion when I sent just that item in. I guess the reinstallation of the 1.42 software was done as a precautionary measure rather than because it was corrupt or had failed, which leaves just the map card as the prime suspect. Although one can't completely rule out the 1.42 software either. At least there's a happy ending! Great customer support from Satmap - it really is their trump card, together with a fantastic product. |
drpeej Occasional Visitor
Joined: May 30, 2008 Posts: 38 Location: Warwickshire
Posted: Sun Feb 07, 2010 10:40 am Post subject: |
I have the same problem after upgrading to 1.4. I note that other users had their problem fixed "under warranty" by Satmap but my Satmap is outside warranty so I dont know where that leaves me.
I will ring them tomorrow.
Peter |
Posted: Tue Feb 09, 2010 10:37 pm Post subject: |
I am pleased to report that I rang Satmap yesterday and today a new platform SD card arrived in the post (no charge)
Even better - it has fixed the problem. The whole-GB SD card is now recognisd and the Active 10 switches on almost instantaneously. There are also a number of other improvements that make the platform upgrade worthwhile.
Thanks Satmap for excellent service and a fantastic piece of kit.
Peter |
paulr Occasional Visitor
Posted: Mon Mar 15, 2010 11:54 am Post subject: |
I'm having the same problem since updating to 1.42. Two cards not being recognised. Satmap have sent me the upgrade SD card but this hasn't sorted the problem. Need to send cards/unit off to satmap. Keeping fingers crossed! _________________ Regards, Paul |
Posted: Mon Mar 15, 2010 8:48 pm Post subject: |
paulr wrote: | I'm having the same problem since updating to 1.42. Two cards not being recognised. Satmap have sent me the upgrade SD card but this hasn't sorted the problem. Need to send cards/unit off to satmap. Keeping fingers crossed! |
Would appreciate an update on this in due course Paul, as this seems pretty close to what my problem was. I expect you'll get two new map cards though! |
Posted: Tue Mar 16, 2010 12:47 am Post subject: |
MikeofDorset wrote: | paulr wrote: | I'm having the same problem since updating to 1.42. Two cards not being recognised. Satmap have sent me the upgrade SD card but this hasn't sorted the problem. Need to send cards/unit off to satmap. Keeping fingers crossed! |
Yep, no problem. All boxed up and ready to post off tomorrow. I'll update as things develop. _________________ Regards, Paul |
dungbeetle Occasional Visitor
Posted: Mon Feb 07, 2011 1:24 pm Post subject: |
Hi.
Just some information/feedback on this topic.
Our Active 10 recently decided that it didn't like our 1:25k Kent Explorer map card any more.
I spoke to the folks at SatMap over the 'phone and they said it would be OK to try backing up the card, reformatting it and then reloading the map, CID and Licence files to see if it could be fixed without having to send the card back to them.
I did this and now the Active 10 recognises the card again.
So, reformatting might be worth a shot if you're having this problem, however I think it's worth clearing it with the SatMap people first, just in case it doesn't work and you still have to send the card back to them after you've tried. _________________ Satmap A10 software version 1.50 (Platform 0)
Satsync version 1.50 |
Posted: Mon Feb 07, 2011 4:21 pm Post subject: |
paulr wrote: | MikeofDorset wrote: | paulr wrote: | I'm having the same problem since updating to 1.42. Two cards not being recognised. Satmap have sent me the upgrade SD card but this hasn't sorted the problem. Need to send cards/unit off to satmap. Keeping fingers crossed! |
Yep, no problem. All boxed up and ready to post off tomorrow. I'll update as things develop. |
Sorry about my late reply!
The unit was checked and the latest software update added. Apparently it is/was a software bug that Satmap are/were aware of and hope to resolve with a future software update. _________________ Regards, Paul |
outdoorsdel Occasional Visitor
Posted: Mon Feb 07, 2011 7:53 pm Post subject: Recognising SD map cards |
I had this problem with the Snowdonia map and was told it was a problem with the latest upgrade. The card was replaced free of charge. |
FrequentFlyer Lifetime Member
Posted: Fri Mar 18, 2011 3:19 pm Post subject: Re: Non-recognition SD Map Card |
PloddinPedro wrote: | lucevans wrote: | If you have ALL* of the files from the map card backed-up somewhere safe, you could try reformatting the SD card using a PC and card reader then copy the files back on to it. N.B. This will only work with the original SD card as each map is locked to the physical card's ID number. Try this at your own risk!! |
That is indeed the process I was informed by Satmap is advisable i.e. they said it was a good idea to back up the official content of your mapcard in case the SD card got corrupted. You could then reformat it and re-install the map data back onto it (but not onto any other SD card, as lucevans correctly says.) |
Does this mean that if I do as above, I could actually include some of my other maps as well, onto one card ? |
