Pocket GPS World :: View topic - New Software 1.420
New Software 1.420
Goto page 1, 2, 3  Next
Bosun
PostPosted: Thu Jan 21, 2010 9:20 pm    Post subject: New Software 1.420 Reply with quote
There is now a new software update on the Satmap site.
http://www.satmap.com/software.php
Ian
lucevans
PostPosted: Thu Jan 21, 2010 9:29 pm    Post subject: A word of caution: Reply with quote
Before installing this version of firmware, be aware that it will display road names from the base vector maps on all maps, including OS 1:50 000 and 1:25 000 maps.
This feature cannot currently be turned off once you have installed the firmware, so be sure that you want road names superimposed on OS maps BEFORE upgrading.
goon525
PostPosted: Thu Jan 21, 2010 9:35 pm    Post subject: Reply with quote
If like me you struggle to get the non-Zip version to work, just try the Zip version, that seems ok. And it has cured the freezing problem on the Trip section of Settings.
PloddinPedro
PostPosted: Thu Jan 21, 2010 10:08 pm    Post subject: Re: A word of caution: Reply with quote
Useful warning, thanks. I'm not sure I want this - the screen is already pretty cluttered and I guess there's more street names in the built up areas. How do these street names appear? If as they do on the base map, do they resize as you zoom out or just disappear?
I wonder why Satmap have done this - I find it difficult to imagine there's been a demand for it from users - ?
What's more alarming is that if this stays as a feature, future software updates will likely also include it, so unless they build in an option to switch it off, we'll eventually get it, like it or not.
Bosun
PostPosted: Thu Jan 21, 2010 10:10 pm    Post subject: Re: A word of caution: Reply with quote
After the upgrade ( which was much easier via Satsync,couldn't download the .exe version ) I still haven't got road names on ANY maps.
Ian
ROBDD1
PostPosted: Thu Jan 21, 2010 10:13 pm    Post subject: Reply with quote
Both versions download but will not run - mentions something about side by side config?
lucevans
PostPosted: Thu Jan 21, 2010 10:17 pm    Post subject: Re: A word of caution: Reply with quote
Ian
They don't appear until you perform a Settings - Default - Yes - Clear All
Once you've done this, you can't turn the road names off!
lucevans
PostPosted: Thu Jan 21, 2010 10:25 pm    Post subject: Re: A word of caution: Reply with quote
I agree with you; I don't want to see road names on OS maps when I'm out walking for the same reason as you - I think they clutter the maps and are distracting. I made this point during beta testing, but there were others who use their A10s for other purposes who really liked this feature. A menu option to turn road name overlay on or off is being considered for a future firmware release apparently. Until then I have decided not to upgrade to v1.42
Bosun
PostPosted: Thu Jan 21, 2010 10:28 pm    Post subject: Re: A word of caution: Reply with quote
Thanks Lucevans,I'll leave things as they are.
Ian
ROBDD1
PostPosted: Thu Jan 21, 2010 10:30 pm    Post subject: Reply with quote
Updated via Satsync however the unit still says version 1.400 -- satsync says v1.4.5471.0 / Platform 09.02.21?? Confused? I have the street names on unit now.
lucevans
PostPosted: Thu Jan 21, 2010 10:39 pm    Post subject: Reply with quote
Have you powered-down the Active 10 since the upgrade? The new version doesn't take effect until the unit is powered down and back up again.
Then on the Active 10 goto Settings - About - then press the upper left button, then the upper right button, then the upper left button again. This will show the exact revision version running on your unit.
PloddinPedro
PostPosted: Thu Jan 21, 2010 10:41 pm    Post subject: Reply with quote
Having looked at the Satmap webpage, I read in the "Resolved Issues" paragraph for this release:-
"For customers using early versions of the unit which are displaying UK vector road maps (this is the simple base map which ONLY shows roads and is NOT the 1:250k OS map), v1.42 will now display roads names."
I note lucevans's comment that they don't actually appear until you do a "Clear All" reset but aren't you supposed to do this anyway?
If the names do come up on top of the OS maps, the above wording doesn't seem very clear to me.
ROBDD1
PostPosted: Thu Jan 21, 2010 10:44 pm    Post subject: Reply with quote
v1.4.5471.0 / Platform 09.02.21 - My revision number.
Many thanks -- Road names on the North Yorks side of things not getting in way on the 1:50 map.
lucevans
PostPosted: Thu Jan 21, 2010 10:54 pm    Post subject: Reply with quote
My experience with the road names from the vector base map being overlaid on OS maps is as follows;
*Some, but not all, road names appear on both 1:25 000 and 1:50 000 scale raster maps.
*Which road names are visible at any given time seems to be dependent on the following factors; current zoom level selected by user, class of road, number of other roads with names in immediate vicinity
*The further out one zooms, the fewer road names are visible.
* As one zooms out, minor roads disappear, leaving only major roads/motorways
*As a rule of thumb, minor (residential) street names on my local 1:25 000 map disappear as I zoom out past approx. 1:15 000; A-roads stay visible much longer, with dual carriageway names remaining visible until at least 1:35 000, and some major arteries (A1, motorways, etc.) are labelled as far out as 1:50 000
I don't know whether any road names are still visible when zoomed out as far as the 1:250 000 scale map - I didn't try this before going back to the earlier firmware version.
lucevans
PostPosted: Thu Jan 21, 2010 10:57 pm    Post subject: Reply with quote
It doesn't sound as if the upgrade fully "took" in that case - maybe try installing it again?
Page 1 of 3
23.032 (12 Mar 25)
