Pocket GPS World :: View topic - "Sorry, request is not included in your subscription&am
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Telmap User Group
mjhanley
PostPosted: Sun Jan 17, 2010 1:27 pm    Post subject: "Sorry, request is not included in your subscription&am Reply with quote
I'm getting the error
"Sorry, request is not included in your subscription"
whenever I try and do anything in Telmap Beta for UG.
Any ideas? Tried re-entering the activation code (in upper and lower case) and it's accepted but I'm still getting the error.
edit: using a blackberry 8900
sherryl1234
PostPosted: Sun Jan 17, 2010 4:24 pm    Post subject: Same error Reply with quote
I'm having the same problem. Some one out there has to know how to fix this. PLEASE!!
Dass
PostPosted: Sun Jan 17, 2010 5:16 pm    Post subject: Reply with quote
Exact same problem on the Storm 9500 - very frustrating...
sherryl1234
PostPosted: Sun Jan 17, 2010 10:25 pm    Post subject: service Not In Subscription Reply with quote
Figured it out
One you enter your activation code, you need to go into preferences-settings-update subscription. Once you're there you need to re-enter the SAME activation code.
Not sure why you have to do this but it worked for me.
Good luck!!
Smile
mjhanley
PostPosted: Sun Jan 17, 2010 10:53 pm    Post subject: Re: service Not In Subscription Reply with quote
Didn't work for me...
sherryl1234
PostPosted: Sun Jan 17, 2010 11:39 pm    Post subject: Reply with quote
Aww...sorry to hear. I'm using a BB Curve 8900 as well and was hoping it would work for everyone.
Sad
eggnoodle
PostPosted: Mon Jan 18, 2010 5:10 pm    Post subject: Reply with quote
I went back to the Preference page and entered 1 letter at a time and I wasn't successful either. I have a Bold 9700, could that be an issue?
sherryl1234
PostPosted: Mon Jan 18, 2010 5:27 pm    Post subject: Reply with quote
I have no idea why it worked for me. I uninstalled the program, then reinstalled it. Yhen I entered my activation code in both spots.
I have no idea if this makes any difference either but I downloaded my version from blackberryseeker.com
Sorry, really thought I was going to be of help.
Sad
Dass
PostPosted: Mon Jan 18, 2010 8:18 pm    Post subject: Reply with quote
Didn't work for me too..........no official response to this?
fpeedy
PostPosted: Tue Jan 19, 2010 8:42 pm    Post subject: Reply with quote
Same here. I'm using a BlackBerry 9520 an get the same error. Any fix?
fpeedy
PostPosted: Wed Jan 20, 2010 8:55 pm    Post subject: Reply with quote
Sorry for my double post, but I got it to work! Cool
In my first attempts I copied the activation key and pasted it into Telmap when I was prompted for the code. But here in the forum someone wrote that you should type the code manually.
But this also doesn't work. Why not? Because I pressed the shift key long, so that every charactar was written in upper case letters - and this was my failure! The thing is, that it seems to be essential that you press shift before you press one key - you have to press shift before every character!
This worked fine for me - I hope so also for you!
Greetings from Germany
mjhanley
PostPosted: Wed Jan 20, 2010 9:05 pm    Post subject: Reply with quote
Still not working for me Sad
fpeedy
PostPosted: Thu Jan 21, 2010 9:51 am    Post subject: Reply with quote
Do you presed "shift" before every letter? Like this: shift - A - shift - B - shift C .......
I fyou did so and it still doesn't work, I'm so sorry!
This method worked for me by the first attempt but sadly it seems that I had only luck. Confused
I hope someone find a fix!
sherryl1234
PostPosted: Thu Jan 21, 2010 9:05 pm    Post subject: Reply with quote
When I entered mine, I didn not copy and paste nor did I bother with Caps. I entered the same code both in lower case letters.
fpeedy
PostPosted: Fri Jan 22, 2010 7:53 am    Post subject: Reply with quote
Lower case letters? When I typed the code in lower type letters I always got the message that the code was incorrect.
Strange that your way worked for you and mine way worked for me but both ways doesn't work on other devices. Shocked
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Telmap User Group All times are GMT + 1 Hour
22.055 (29 May 24)
