Fraserp Lifetime Member
Joined: Jun 15, 2004 Posts: 297 Location: Manchester, UK
Posted: Wed Jul 14, 2004 6:12 am Post subject: Starting a route from another location? |
I doing something dumb again!
Planning a rout to start from another location, i.e not home or present location. I've set drive by's and checked it out. But navigation is allways begining from where I am (GPS location). How can I stop this from happening?
Thanks _________________ Fraserp
TomTom 1000
GPSmap 60CSx
SatMap
MrT Frequent Visitor
Posted: Wed Jul 14, 2004 6:24 am Post subject: |
Go to the location where you want to start navigating from?
I am not sure why you would want to do this. If you explained this, an answer may be easier.
If it is for a future trip create an itinery then save it, then clear it. Load it when you need it.
If you want to drive without using the navigator function, program the route then turn guidance off. |
Posted: Wed Jul 14, 2004 7:02 am Post subject: |
I am running it from an itinerary that is already created.
I just want to:-
1) load a route and view it.
2) go over a planned route from the intended starting point, not anywhere else.
The only way that ihave , just, found is to turn off the GPS SW, then the start location appears. But I keep being prompted to load a BT device...
On my system, turning guidance off, stops route calculation, and the route is not displayed.
As I said earlier, it's probably me doing smething dumb!
TomTom 1000
GPSmap 60CSx
SatMap
Posted: Wed Jul 14, 2004 7:58 am Post subject: |
Look at it in map view rather than in Navigator?
After planning the route in itinery, click on the map button. |
johnmar Regular Visitor
Joined: 21/02/2003 11:37:04 Posts: 164 Location: United Kingdom
Posted: Wed Jul 14, 2004 8:52 am Post subject: |
If you want to review a route from a saved itinieary, you may have to reset the start point:
1. Open itinieary
2. Tap and hold on your start point, probably item 1 and sellect "Set as Depature"
3. Run "PLAN", you will probably be asked to confirm sart point from a drop-down window which should NOW include your choice.
4. Go to MAP and the route (as per the Itinieary) should be set.
Hope this answers your question _________________ John
iPAQ3830 (32MB) PPC2002 ROM 1.20
CF Expansion Pack
Holux GR-213 GPS Mouse (GSW3.1.1 -3.1.00.07 C23B1.00)
Kingston Elite Pro 1 GB CF Card for maps
Viking 512MB SD Card (not used for navigating)
TTNav 5.210 (5430) Maps of W Europe |
Posted: Wed Jul 14, 2004 9:03 am Post subject: |
Thanks that all clear now. _________________ Fraserp
TomTom 1000
GPSmap 60CSx
SatMap
