kostaschrys Occasional Visitor
Posted: Thu Jan 07, 2010 9:28 pm Post subject: |
Hi linknet,
Thanks for the help. I created the button and works fine. I made a new data.zip with the modifications. The only problem I have is that the mouse pointer is always visible on I go navigating screen. Any idea how to hide it.
Regards
Kostaschrys |
linknet Frequent Visitor
Posted: Fri Jan 08, 2010 12:06 am Post subject: |
kostaschrys wrote: | Hi linknet,
Regards
Kostaschrys |
That's good.
When you say "mouse pointer" is that actually a mouse pointer or is there something lost in the translation ?
Regards
linknet |
Posted: Fri Jan 08, 2010 12:40 pm Post subject: |
Hi linknet,
Indeed a real mouse pointer, a working one, where you press with your finger moves with it. Probably it is hidemouse=1 text, somewhere on my data modifications and I get that.
Any idea?
Regards
Kostaschrys |
Posted: Fri Jan 08, 2010 12:44 pm Post subject: |
Hi linknet,
Any idea?
Regards
Kostaschrys |
Posted: Fri Jan 08, 2010 12:45 pm Post subject: |
Hi linknet,
Any idea?
Regards
Kostaschrys |
Posted: Fri Jan 08, 2010 12:48 pm Post subject: |
Hi linknet,
Any idea?
Regards
Kostaschrys |
Posted: Fri Jan 08, 2010 12:57 pm Post subject: |
Kostaschrys |
I've not heard of that before, quite useful if you're not using the device for navigation. Out of interest which device are you using and is the mouse pointer part of the operating system.
I don't know how you would disable it though.
Regards
linknet |
Posted: Fri Jan 08, 2010 6:54 pm Post subject: |
Regards
linknet[/quote]
I am using a car navigation box, that support navigation and other windows CE players. THe box is called navibox OS 500 I think.
I found the solution to the pointer
There is a file in data:
Data\config\devices\wonderproud.ini όπου where inside has:
[interface]
maxzoom2d=6000000
show_exit=1
hide_mouse=0
Changing to hide_mouse=1 the pointer is disabled.
Regards
Kostaschrys |
Posted: Fri Jan 08, 2010 8:38 pm Post subject: |
kostaschrys wrote: | I found the solution to the pointer:
Regards
Kostaschrys |
All problems solved then.
Regards
linknet |
JackDo Occasional Visitor
Posted: Thu Jan 14, 2010 8:50 am Post subject: New version + DA |
Using your skin for a long time and would not like to replace it.
I have Loox N560 with 640x480 (portrait).
Will you support the new release 8.3.4.117940 and _da?
Thanks |
Posted: Thu Jan 14, 2010 12:11 pm Post subject: Re: New version + DA |
JackDo wrote: | Hi,
Thanks |
I'm hoping that at some point Nav'n'Go will redesign the iGO8 interface to be comparable with the Amigo interface. Therefore I've put the iGO8 Ultra Skin on hold for the time being. By the way, what is DA ?
Regards
linknet |
M8TJT The Other Tired Old Man
Posted: Thu Jan 14, 2010 12:15 pm Post subject: Re: New version + DA |
linknet wrote: | By the way, what is DA ? |
It's Driver Alert. Used with only Navtech maps. Gives alerts for schools and lots of other stuff. No so many signposts in NT maps though |
Posted: Thu Jan 14, 2010 12:30 pm Post subject: Re: New version + DA |
M8TJT wrote: | linknet wrote: | By the way, what is DA ? |
Thanks for that. I knew that driver alert was included in 8.3.4.117940 so I should have realised that DA was the acronym.
Regards
linknet |
majB Occasional Visitor
Posted: Sat Jan 23, 2010 3:28 pm Post subject: |
Is there away to make the background of the cruise arrows transparent (the upper left corner).
In a PNA of 320x240 it is eating about 1/4 of the screen. I thought making the background transparent will improve the visibility of the map just like in the Dimka skin.
thanks! |
Posted: Sat Jan 23, 2010 7:09 pm Post subject: |
majB wrote: | Is there away to make the background of the cruise arrows transparent (the upper left corner).
thanks! |
It's possible to make the "Next Route Event" (as Nav'n'Go call it) transparent but in my opinion it makes it harder to read so I haven't included this option.
linknet |
