MarkMarkB Regular Visitor
Posted: Tue Dec 29, 2009 2:19 pm Post subject: Buying TomTom maps - any tips? |
I need to buy a TomTom map of New Zealand. Is downloading it a straightforward process or is there anything I need to be aware of?
Presumably once downloaded I should make a back up onto my PC in the usual way.
Thanks. |
dhn Frequent Visitor
Joined: Oct 08, 2007 Posts: 2544 Location: Toronto CANADA
Posted: Tue Dec 29, 2009 2:26 pm Post subject: |
You don't say what model TomTom you have but if it is one with a sdhc card, make sure when you first connect to Home, you signify where you want the map installed, internal or card, by selecting your choice at startup.
I, too, bought the NZ map about three or four months ago. It's relatively small in size but bloody expensive!
Anyway, I chose to have it go on the same 4-gig sdhc card as I have my North america map. Just remember if you plan to put it in a location where another map resides, you must go to manage maps--select map--and choose the proper map when you want to get mapshare updates using Home.
Yes, once downloaded and installed, make a backup (Explorer) of your NZ map to the computer. _________________ David |
Posted: Tue Dec 29, 2009 2:31 pm Post subject: |
Sorry, it's a 930T without a memory card.
So, if I understand correctly, I should:-
1) Download the map to the internal memory.
2) Make a copy using Windows Explorer.
3) Select the NZ map and the do a Mapshare.
Is that correct? Thanks again. |
Posted: Tue Dec 29, 2009 2:36 pm Post subject: |
Yes, those steps will work. _________________ David |
Posted: Tue Dec 29, 2009 2:38 pm Post subject: |
Thank you. |
