PhilB Lifetime Member
![](modules/Forums/images/avatars/gallery/081.gif)
Posted: Fri Dec 25, 2009 12:11 pm Post subject: Anyone managed to load all the cameras on the new WM update? |
Hi All,
I've managed to load the new WM update but having problems loading the speed cameras. I've tried the trusted way of deleting the folders from user places and then copying the new files into save but only the camera icons and the gatso file get imported the remaining csv files get left in save. I've also tried using central but that seems to be the same only the gatso file gets imported.
Has anyone managed to import all of the files yet?
Phil |
adamwolfe Lifetime Member
![](modules/Forums/images/avatars/287861486486c924a914d3.gif)
Joined: Apr 26, 2007 Posts: 101 Location: Scottish Borders
Posted: Sat Dec 26, 2009 12:28 pm Post subject: Re: Anyone managed to load all the cameras on the new WM upd |
PhilB wrote: | Hi All,
Phil |
I also tried several times using the usual methods - no joy at all. Other poi load fine from the poi download section but I use the TT versions which work fine if you change the pictures to .png and delete the .bmp ones. I thought if the poi work, why not try the camera TT files? I kept the original .png camera pics and used the TT location files. Followed the same procedure as before and it seems to work. I haven't used in real time but I have run several demo routes. Cameras show but not with PGPSW pic files ??? The generic yellow camera pics show but the actual speeds seem to display properly. If anyone else can throw any light on this I'm sure many would be interested.
Cheers _________________ Adam |
lodgebarn Occasional Visitor
Posted: Mon Dec 28, 2009 11:13 pm Post subject: |
Some success for me with the update, what I noticed is that the Copilot load procedure actually created a folder called pocketgps_uk i.e. dropping the data after the second underscore from the pocketgps_uk_gatso.csv file. This meant that only the first speed camera file was loaded. I also had another custom poi file where I observed the same effect.
What I then did was to remove the _uk from the file names (including png) and try again - leaving names such as pocketgps_gatso. This time Copilot loaded all speed cameras successfully. Since I am not on the road I cannot test that the cameras will work.
Good luck to all copilot sufferers . |
MaFt Pocket GPS Staff
![](http://maft.co.uk/avatars/pgpsw.jpg)
Joined: Aug 31, 2005 Posts: 15157 Location: Bradford, West Yorkshire
Posted: Tue Dec 29, 2009 10:10 am Post subject: |
it makes sense... this 'feature' was also added to the android version...
i'll take a look at the download code and see if i can get it to rename them.
MaFt |
Posted: Tue Dec 29, 2009 10:11 am Post subject: |
lodgebarn wrote: | Some success for me with the update, what I noticed is that the Copilot load procedure actually created a folder called pocketgps_uk i.e. dropping the data after the second underscore from the pocketgps_uk_gatso.csv file. This meant that only the first speed camera file was loaded. I also had another custom poi file where I observed the same effect.
Well spotted! I had noticed the folder but not realised the signifigance. Have used your method of changing file names and according to various demos run that go past known camera locations it works perfectly. Going out later and will try in real time. Also I have loaded various other poi files using .png and .ov2 files from this site and they work fine as well. Strange that only the camera files need editing, guess CoPilot uses these in a different way
Anyhoo many thanks for your help.
Posted: Tue Dec 29, 2009 10:16 am Post subject: |
MaFt wrote: | it makes sense... this 'feature' was also added to the android version...
MaFt |
Thanks MaFt - knew it wouldn't be long before we saw you here.... ![Clap](modules/Forums/images/smiles/div348.gif) _________________ Adam |
Posted: Tue Dec 29, 2009 10:22 am Post subject: |
Ah, that's good news, I'll give the update another go then |
Posted: Tue Dec 29, 2009 10:27 am Post subject: |
changes to filename now made - see here
MaFt |
Posted: Tue Dec 29, 2009 12:32 pm Post subject: |
Good man!
Very many thanks for your help, if only ALK were as responsive.
Best wishes for the New Year
Phil |
