Pocket GPS World :: View topic - CoPilot Central
CoPilot Central
FrequentFlyer
PostPosted: Mon Dec 28, 2009 12:57 pm    Post subject: CoPilot Central Reply with quote
As a non techy, I would appreciate a bit of help with installing CoPilot Central. I am unable to delete an earlier version, using add/delete programs, or absolute uninstaller, or going into the program folders and deleting anything to do with ALK. Each time I try to uninstall , it thinks I am trying to install, and if I try to install, it says delete the old one first....what do you suggest I do now ? Thanks.
adamwolfe
PostPosted: Tue Dec 29, 2009 10:22 am    Post subject: Re: CoPilot Central Reply with quote
You could try running the new installation file regardless. From memory I seem to remember being asked if the old version should be removed first. In other words the program over writes its self anyway. Alternatively reinstall the old version to put everything back where it should be and try uninstalling via add/remove again. Good luck Smile
Adam
22.062 (12 Jun 24)
